RaceCapture on Raspberry Pi
Benefits
Experimental!
While the results are pretty great, these instructions are currently for those adventurous race car hackers who know their away around a command line, comfortable working with hardware and want to dig in. Think it's cool, but too much to tackle? Rope in your nearest computer/electronics geek - you need one on your race team, anyway. :)
Hardware Selection
Raspberry Pi
Display
Power Supply
To power everything, you'll need a high quality 2 amp charger - preferably one designed to be hard wired into your car for maximum reliability.
Heat sinking
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
Connect your RaceCapture/Pro or RaceCapture/Track to the Raspberry Pi using the USB cable. Once the app is running and RaceCapture is connected, you'll it connect automatically.
Use the app just as you would on Android or iOS.
