ShiftX2
In the kit you will receive:
- ShiftX2 module
- 4 wire pigtail
- Acrylic enclosure
Assembling the enclosure
Mounting ShiftX2
Pinout
| Red | 5-12v Power | Connect this to switched ignition power. 0.5A max consumption. |
| Black | CAN High | |
| Yellow | CAN Low | |
| White | Ground |
Power
CAN bus connections
Scripts
Disco Lights Demo
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
function rndc()
return math.random(0,255)
function sxOnUpdate()
for i=0,9,1 do
r = rndc()
g = rndc()
b = rndc()
sxSetLed(i,1,r,g,b,0)
function sxOnBut(b)
println('button: ' ..b)
function sxOnInit()
print('sx onInit')
--ShiftX2 library functions--
sxTx(10,{i,l,r,g,b,f})
sxTx(3,{bright})
sxTx(20,{id,r,g,b,f})
function sxUpdateAlert(id,v)
sxTx(42,{spl(v),sph(v)})
function sxInit()
println('config shiftX2')
sxSetBaseConfig(sxBright)
function sxChkCan()
id,ext,data=rxCAN(sxCan,0)
function sxProcess()
sxChkCan()
function sxTx(offset, data)
sleep(10)
sxProcess()
sxInit()
Sequential shift light
Script
- Default is reading RPM via OBDII. You can change to direct RPM input in the script.
sxCan = 1
sxId=0
tickRate=30
sxBright=0
function sxOnInit()
println('on init')
--config shift light
function sxOnBut(b)
---ShiftX2 functions
sxTx(3,{bright})
function sxInit()
setBaseConfig(sxBright)
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
sxInit()
Assumptions:
- Engine Temperature on the 1st alert LED, connected to first analog channel
- Oil Pressure on the 2nd alert LED, connected to second analog channel
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
--update engine temp alert
sxUpdateAlert(0, getAnalog(0))
--update oil pressure alert
sxUpdateAlert(1, getAnalog(1))
function sxOnInit()
sxSetAlertThresh(1,0,0,255,0,0,10) --red flash below 15 psi
function sxOnBut(b)
sxTx(3,{bright})
function sxInit()
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
sxInit()
Script
Boost Gauge
Script
Only Alerts
- Left alert for oil pressure
Script
ShiftX2 starter script
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function sxOnInit()
function sxOnBut(b)
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
sxTx(3,{bright})
function sxInit()
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
sxInit()
ShiftX2 CAN bus API
| Offset | What | Value |
| 0 | Brightness | 0 - 100; default = 0 (0=automatic brightness) |
| 1 | Automatic brightness scaling (Optional) | 0-255; default=51 |
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Set Linear Graph Threshold
CAN ID: Base + 41
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 42
| 0 | Value (low byte) | |
| 1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
