AnalogX
AnalogX CAN bus API
Adjusting Base ID
The base address is determined by the state of the ADR1 and ADR2 jumpers. By default, the jumpers are bridged; cutting the jumper ADR1 will add 256 to the base ID, and cutting jumper ADR2 will add 512 to the base ID.
ADR2 ADR1 Address
Default Default 0xE4600 (935424)
Default Cut 0xE4700 (935680)
Cut Default 0xE4800 (935936)
Cut Cut 0xE4900 (936192)
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Send this message to AnalogX to configure runtime settings. These settings are volatile.
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
