AnalogX
AnalogX CAN bus API
Adjusting Base ID
Closed | Closed | 0xE4600 (935424) |
Closed | Open | 0xE4700 (935680) |
Open | Closed | 0xE4800 (935936) |
Open | Open | 0xE4900 (936192) |
Address
Offset | What | Value |
0 | Channel Count | Total number of channels on device |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Major Version | Firmware Major Version Number |
6 | Minor Version | Firmware Minor Version Number |
7 | Patch Version | Firmware Patch version number |
Configuration Group 1
Send this message to AnalogX to configure runtime settings. These settings are volatile.
Address
0 | Sample Rate | Rate to report sensor values ( 1 - 255Hz). Default sample rate is 50Hz. |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Reserved | |
6 | Reserved | |
7 | Reserved |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
0 | Channel 1, low byte | |
1 | Channel 1, high byte | |
2 | Channel 2, low byte | |
3 | Channel 2, high byte | |
4 | Channel 3, low byte | |
5 | Channel 3, high byte | |
6 | Channel 4, low byte | |
7 | Channel 4, high byte |
