BMW E30 Guide
Revision as of 01:19, 14 November 2017 by Sbarton (talk | contribs) (→‎RPM)
BMW E30 (1982 to 1993)
Use the Black wire in the C101 plug feeding from the ECU to the instrument cluster. It is located closer to the driver's door side of the instrument cluster.
RaceCapture/Pro timer configuration
  • Timer Mode: RPM
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Engine Temperature
Map values in RCP:
  • 2.65v = 85
  • 2.55v = 120
  • 2.06 = 195
  • 1.83 = 220
  • 0.80 = 310
Fuel Level
Map values in RCP:
  • 4.3v = 0 (empty)
  • 2.28v = 50 (half)
  • 0.55v = 100 (full)
Oil Pressure
