ShiftX3
In the kit you will receive:
- ShiftX3 module
- 2 M2x5mm screws for enclosure assembly
- 2 #6 screws for surface mounting
(3D printed enclosure not included)
Dimensions
- ShiftX3 bare board: 114 x 27mm (4.48 x 1.06 inches)
ShiftX3 is designed to be surface mounted with the companion enclosure, or it can be embedded into your dashboard in a custom installation.
Printing the enclosure
The enclosure can be 3D printed by downloading the printer files.
File:Shiftx3 enclosure rev A.zip
The enclosure consists of the following parts:
- shiftx3.stl : Main housing for ShiftX3 - Qty 1 needed
- shiftx3_back_3dprint: Back cover for housing - Qty 1 needed
- shiftx3_light_pipe.stl: Light pipe for LEDs - Qty 9 needed
- shiftx3_light_pipe_photosensor.stl: Light pipe for photosensor - Qty 1 needed
Color and material are not critical for the enclosure; however we recommend PETG or ABS.
Printing light pipes
Print the 9 LED light pipes and 1 photosensor light pipe in clear filament. PETG is recommended for optical clarity.
Enclosure clean up
Ensure extra filament is completely removed from the inside of the enclosure and is completely clean, so ShiftX3 board can fit flush and level inside the enclosure.
3D printing notes
- Print extra light pipes and print with a brim to purge heat-scorched / darkened filament from the extruder.
- Avoid printing just one light pipe at a time - printing just one will cause the part to sag and deform due to concentrated heat in the small part. We recommend you print at least 4 at a time to ensure heat is distributed across the parts and retain dimensional accuracy.
Assembling the enclosure
Install light pipes
Press the LED light pipes into the enclosure from the back side, ensuring they are flush with the front.
- Note -The LED light pipes have a small lip that locks into the back surface.
Press the photo sensor light pipe into the front of the enclosure. There should be a tight interference fit; if there is not, use a tiny drop of super glue from the back side of the enclosure to secure it.
Install ShiftX3
Install ShiftX3 into the back of the enclosure, guiding the switches into their respective hole.
- Note - Take care to not torque the switch handles sideways to prevent damage.
Gently press the back of ShiftX3 board so that it is fully seated into the enclosure. There should be a 0.5mm lip around the back of the enclosure where the back plate will lock into place.
Install the back panel of ShiftX3 so the shallow lip of the back panel sits within the recess of the ShiftX3 enclosure.
When pressed together, there should be no gap between the enclosure and the back plate. If there is, check the inside of the enclosure to clean up any additional 3D printed filament.
Secure the back plate using the two M2x5mm screws. Do not over-torque.
Connection and Installation
Mounting ShiftX3
Integration with RaceCapture / PodiumConnect
Suggested parts:
- RJ45 Splitter "Hub" shaped
Patching the RJ45 cable to ShiftX3
You will need to splice ShiftX3 to the conductors of the patch cable. Start by snipping the RJ45 connector off the end of a patch cable, and then expose the individual wires.
| ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
| Red | +12v | Brown |
| Black | CAN 2 High | Blue |
CAN termination is enabled by default. To disable termination, cut the CAN Term jumper on the bottom of ShiftX3.
Scripts
Disco Lights Demo
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
disp = 0
function rndc()
return math.random(0,255)
function sxOnUpdate()
for i=0,9,1 do
r = rndc()
g = rndc()
b = rndc()
sxSetLed(i,1,r,g,b,0)
--sxSetDisplay(math.random(0,9))
function sxOnBut(b, id)
println('button: ' ..b ..' ' ..id)
if b == 0 then return end
if id == 1 then disp = disp + 1 end
if id == 0 then disp = disp - 1 end
sxSetDisplay(disp)
function sxOnInit()
print('sx onInit')
--ShiftX3 library functions--
sxTx(10,{i,l,r,g,b,f})
sxTx(3,{bright})
sxTx(20,{id,r,g,b,f})
function sxSetDisplay(value)
sxTx(50, {0, 48+value})
function sxUpdateAlert(id,v)
sxTx(42,{spl(v),sph(v)})
function sxInit()
println('config ShiftX3')
sxSetBaseConfig(sxBright)
function sxChkCan()
id,ext,data=rxCAN(sxCan,0)
if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1], data[2]) end
function sxProcess()
sxChkCan()
function sxTx(offset, data)
sleep(10)
sxProcess()
println('Shiftx3 base id ' ..sxCanId)
sxInit()
Sequential shift light
Script
- Default is reading RPM via OBDII. You can change to direct RPM input in the script.
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2
sxCan = 1
-- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut)
sxId=0
--how often ShiftX3 is updated
tickRate=30
sxBright=0
--add your code to update ShiftX3 alerts or linear graph during run time.
function sxOnInit()
--config shift light
function sxOnBut(b)
println('button: ' ..b)
---ShiftX3 functions
sxTx(3,{bright})
function sxInit()
setBaseConfig(sxBright)
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
sxInit()
Assumptions:
- Engine Temperature on the 1st alert LED, connected to first analog channel
- Oil Pressure on the 2nd alert LED, connected to second analog channel
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
--update engine temp alert
sxUpdateAlert(0, getAnalog(0))
--update oil pressure alert
sxUpdateAlert(1, getAnalog(1))
function sxOnInit()
sxSetAlertThresh(1,0,0,255,0,0,10) --red flash below 15 psi
function sxOnBut(b)
sxTx(3,{bright})
function sxInit()
println('config shiftX3')
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
println('shiftX3 base id ' ..sxCanId)
sxInit()
Script
-- Predictive time visualizer
sxCan = 1
sxId=1
tickRate=30
sxBright=0
--save best lap time
bestTime = 0
-- rail values
sxUpdateLinearGraph(timeDiff)
function sxOnInit()
function sxOnBut(b)
bestTime = 0
sxTx(3,{bright})
function sxInit()
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
sxInit()
Boost Gauge
Assumptions
- MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
sxCan = 1
sxId=1
tickRate=30
sxBright=0
--convert to PSI boost
sxUpdateLinearGraph(boost)
println(map ..' ' ..boost)
function sxOnInit()
function sxOnBut(b)
sxTx(3,{bright})
function sxInit()
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
println('ShiftX3 base id ' ..sxCanId)
sxInit()
Only Alerts
- Left alert for oil pressure
Script
ShiftX3 starter script
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function sxOnInit()
--add your code for configuring ShiftX3. Runs once during startup
function sxOnBut(b)
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
sxTx(3,{bright})
function sxInit()
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
sxInit()
ShiftX3 CAN bus API
| Offset | What | Value |
| 1 | Automatic brightness scaling (Optional) | 0-255; default=51. adjust this value to adjust the relative gain of the built-in light sensor when in automatic brightness mode. |
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Set Linear Graph Threshold
CAN ID: Base + 41
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 42
| 0 | Value (low byte) | |
| 1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
