RCP stimulator
Revision as of 03:02, 6 January 2019 by Brentp (talk | contribs) (→Example Lua script to read serial data)
RS232 serial output
Baud Rate
Baud rate is 115200, 8N1
Format
- Timestamp in milliseconds
- Channel 1 value (0-10000)
- Channel 2 value (0-10000)
- Channel 3 value (0-10000)
- Channel 4 value (0-10000)
--initialize Aux serial port to 115200, 8, N, 1 initSer(6, 115200, 8, 0, 1) setTickRate(10) function onTick() --read a line from the aux serial port with a 100ms timeout value = readSer(6, 100) if value ~= nil and value ~= '' then print('read value: ' ..value) end end
38817 ,0,0,0,0 39017 ,0,0,0,0 39217 ,0,0,0,0 39417 ,0,0,0,0 39617 ,0,0,0,0 39817 ,0,0,0,0 40017 ,0,0,0,0 40217 ,0,0,0,0 40417 ,0,0,0,0 40617 ,0,0,0,0 40817 ,0,0,0,0 41017 ,302,0,0,0 41217 ,1110,0,0,0 41417 ,1940,0,0,0 41617 ,1943,0,0,0 41817 ,1943,0,0,0 42017 ,1940,0,0,0 42217 ,1942,717,0,0 42417 ,1935,1321,0,0 42617 ,1935,1363,0,0 42817 ,1938,1363,0,0 43017 ,1940,1363,0,0 43217 ,1937,1362,795,0 43417 ,1938,1360,1478,0 43617 ,1939,1362,1473,0 43817 ,1938,1360,1477,0 44017 ,1937,1358,1477,0 44217 ,1938,1360,1476,513 44417 ,1934,1359,1477,1482 44617 ,1938,1360,1474,1489
