ShiftX3
Revision as of 01:49, 9 January 2019 by Brentp (talk | contribs) (→‎Script)
In the kit you will receive:
  • ShiftX3 module
  • 2 M2x5mm screws for enclosure assembly
(3D printed enclosure not included)
Dimensions
  • ShiftX3 bare board: 114 x 27mm (4.48 x 1.06 inches)
ShiftX3 is designed to be surface mounted with the companion enclosure, or it can be embedded into your dashboard in a custom installation.
Printing the enclosure
The enclosure can be 3D printed by downloading the printer files.
File:Shiftx3 enclosure rev A.zip
The enclosure consists of the following parts:
  • shiftx3.stl : Main housing for ShiftX3 - Qty 1 needed
  • shiftx3_back_3dprint: Back cover for housing - Qty 1 needed
  • shiftx3_light_pipe.stl: Light pipe for LEDs - Qty 9 needed
  • shiftx3_light_pipe_photosensor.stl: Light pipe for photosensor - Qty 1 needed
Color and material are not critical for the enclosure; however we recommend PETG or ABS.
Printing light pipes
Print the 9 LED light pipes and 1 photosensor light pipe in clear filament. PETG is recommended for optical clarity.
Enclosure clean up
Ensure extra filament is completely removed from the inside of the enclosure and is completely clean, so the ShiftX3 circuit board can fit flush and level inside the enclosure.
3D printing notes
  • Print extra light pipes and print with a brim to purge heat-scorched / darkened filament from the extruder.
  • Avoid printing just one light pipe at a time - printing just one will cause the part to sag and deform due to concentrated heat in the small part. We recommend you print at least 4 at a time to ensure heat is distributed across the parts and retain dimensional accuracy.
Assembling the enclosure
Install light pipes
Press the LED light pipes into the enclosure from the back side, ensuring they are flush with the front.
  • Note -The LED light pipes have a small lip that locks into the back surface.
Press the photo sensor light pipe into the front of the enclosure. There should be a tight interference fit; if there is not, use a tiny drop of super glue from the back side of the enclosure to secure it.
Install ShiftX3
Install ShiftX3 into the back of the enclosure, guiding the switches into their respective hole.
  • Note - Take care to not torque the switch handles sideways to prevent damage.
Gently press the back of ShiftX3 board so that it is fully seated into the enclosure. There should be a 0.5mm lip around the back of the enclosure where the back plate will lock into place.
ShiftX3 in white ABS
ShiftX3 in black ABS
Install the back panel of ShiftX3 so the shallow lip of the back panel sits within the recess of the ShiftX3 enclosure.
When pressed together, there should be no gap between the enclosure and the back plate. If there is, check the inside of the enclosure to clean up any additional 3D printed filament.
Secure the back plate using the two M2x5mm screws. Do not over-torque.
Connection and Installation
Mounting ShiftX3
Integration with RaceCapture / PodiumConnect
Suggested parts:
  • RJ45 Splitter "Hub" shaped
Patching the RJ45 cable to ShiftX3
You will need to splice ShiftX3 to the conductors of the patch cable. Start by snipping the RJ45 connector off the end of a patch cable, and then expose the individual wires.
Red +12v Brown
White Ground Orange/White
Black CAN 2 High Blue
Yellow CAN 2 Low Blue/White
CAN termination is enabled by default. To disable termination, cut the CAN Term jumper on the bottom of ShiftX3.
Scripts
Disco Lights Demo
Script
This script will randomly set LEDs with different colors, and the navigation buttons will cycle the display number up and down.
sxCan = 1
sxId=0
tickRate=30
sxBright=0
sxAutoBrightScaling=51
disp = 0
orientInverted = 1
function rndc()
  return math.random(0,255)
function sxOnUpdate()
  for i=0,9,1 do
    r = rndc()
    g = rndc()
    b = rndc()
	sxSetLed(i,1,r,g,b,0)
function sxOnBut(b, id)
  println('button: ' ..b ..' ' ..id)
  if b == 0 then return end
  if id == 1 then disp = disp + 1 end
  if id == 0 then disp = disp - 1 end
  sxSetDisplay(disp)
function sxOnInit()
  print('sx onInit')
--ShiftX3 library functions--
  sxTx(10,{i,l,r,g,b,f})
  sxTx(3,{bright,sxAutoBrightScaling,orientInverted})
  sxTx(20,{id,r,g,b,f})
function sxSetDisplay(value)
  sxTx(50, {0, 48+value})
function sxUpdateAlert(id,v)
  sxTx(42,{spl(v),sph(v)})
function sxInit()
  println('config ShiftX3')
  sxSetBaseConfig(sxBright)
function sxChkCan()
  id,ext,data=rxCAN(sxCan,0)
  if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1], data[2]) end
function sxProcess()
  sxChkCan()
function sxTx(offset, data)
  sleep(10)
  sxProcess()
println('Shiftx3 base id ' ..sxCanId)
sxInit()
Sequential shift light
Script
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2
sxCan = 1
-- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut)
sxId=0
--how often ShiftX3 is updated
tickRate=30
sxBright=0
--Auto brightness scaling. No need to change this
sxAutoBrightScaling=61
--ShiftX3 orientation - 1 = inverted, with display above LED graph.
sxOrientInverted  = 1
  --add your code to update ShiftX3 alerts or linear graph during run time.
function sxOnInit()
  --config shift light
function sxOnBut(b)
  println('button: ' ..b)
---ShiftX3 functions
  sxTx(3,{bright, sxAutoBrightScaling, sxOrientInverted})
function sxInit()
  setBaseConfig(sxBright)
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
Assumptions:
Script
sxCan = 1
sxId=0
tickRate=50
sxBright=50
  --update engine temp alert
  --update oil pressure alert
  sxSetDisplay(5)
function sxOnInit()
function sxOnBut(b)
function sxInit()
  println('config shiftX3')
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
println('shiftX3 base id ' ..sxCanId)
sxInit()
Script
-- Predictive time visualizer
sxCan = 1
sxId=1
tickRate=30
sxBright=0
--save best lap time
bestTime = 0
  -- rail values
  sxUpdateLinearGraph(timeDiff)
function sxOnInit()
function sxOnBut(b)
  bestTime = 0
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
Boost Gauge
Assumptions
  • MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
sxCan = 1
sxId=1
tickRate=30
sxBright=0
  --convert to PSI boost
  sxUpdateLinearGraph(boost)
  println(map ..' ' ..boost)
function sxOnInit()
function sxOnBut(b)
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
println('ShiftX3 base id ' ..sxCanId)
sxInit()
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX3 starter script
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function sxOnInit()
  --add your code for configuring ShiftX3. Runs once during startup
function sxOnBut(b)
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
ShiftX3 CAN bus API
Offset What Value
Offset What Value
Offset What Value
Set Display
CAN ID: Base + 50
Offset What Value
0 Digit index 0 (must be 0)
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
