ShiftX3
In the kit you will receive:
- ShiftX3
- 2 #6 screws for surface mounting
Dimensions
Connection and Installation
Mounting ShiftX3
- RJ45 Splitter
- RJ45 network cable
OBDII Cable integration
OBDII installation is effectively plug and play:
Non OBDII installation
RJ45 power cable for ShiftX3
| ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
| Red | +12v | Brown |
| Black | CAN 2 High | Blue |
CAN Base Address
The default CAN base address is 935424 (0xE4600). You can change it by breaking the trace bridging the ADR1 jumper on the bottom of the ShiftX3 circuit board.
| Closed (Default setting) | 935424 (0xE4600) |
| Open | 935680 (0xE4700) |
CAN Baud Rate
| Closed (Default setting) | 500K |
| Open | 1MB |
Scripts
Disco Lights Demo
Script
setTickRate(30)
-- Set configuration. Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar)
sxSetConfig(1, 0xE4600, bright,sxAutoBrightScaling,orientInverted)
function rndc()
return math.random(0,255)
for i=0,9,1 do
r = rndc()
g = rndc()
b = rndc()
sxSetLed(i,1,r,g,b,0)
Sequential shift light
Script
setTickRate(30)
-- Set ShiftX3 configuration
sxSetConfig(1, 0xE4600, 0, 61, 0)
--config shift light
Assumptions:
Script
setTickRate(30)
--update RPM
--update engine temp alert
--update oil pressure alert
Script
-- Predictive time visualizer --save best lap time bestTime = 0 -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(1,0,0,200) --center-out graph, linear style, +/- 10.0 seconds in 0.1 sec resolution sxSetLinearThresh(0,0,0,255,0,0,0) --red if you're falling behind best lap sxSetLinearThresh(1,0,80,0,0,255,0) --blue if you're close to best lap sxSetLinearThresh(2,0,110,0,255,0,0) --green if you're beating best lap setTickRate(30) function onTick() local predTime = getPredTime() local timeDiff = (bestTime - predTime) * 60 -- rail values timeDiff = math.max(timeDiff, -10) timeDiff = math.min(timeDiff, 10) --scale values from +/- 10 sec to a 0-200 scale timeDiff = (timeDiff + 10) * 10 sxUpdateLinearGraph(timeDiff) --update best lap time if an updated lap time is available local lastLapTime = getLapTime() if lastLapTime < bestTime or bestTime == 0 then bestTime = lastLapTime end end
Boost Gauge
Assumptions
Script
setTickRate(30)
local map = getChannel("MAP")
--convert to PSI boost
sxUpdateLinearGraph(boost)
ShiftX3 CAN bus API
| Offset | What | Value |
| 1 | Automatic brightness scaling (Optional) | 0-255; default=51. adjust this value to adjust the relative gain of the built-in light sensor when in automatic brightness mode. |
Set Display
CAN ID: Base + 50
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Set Linear Graph Threshold
CAN ID: Base + 41
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 42
| 0 | Value (low byte) | |
| 1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
