ShiftX3
- ShiftX3
- 2 #6 screws for surface mounting
- ShiftX3
- RJ45 CAN hub
- Low profile RJ45 Cable
Dimensions
Compatibility
ShiftX3 is compatible with:
- RaceCapture/Track MK2
- RaceCapture/Pro MK2 and MK3
- RaceCapture/Apex
- PodiumConnect
Connection and Installation
Mounting ShiftX3
- RJ45 Splitter
- RJ45 network cable
Non OBDII installation
- Note:
RJ45 power cable for ShiftX3
| ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
| Red | +12v | Brown |
| Black | CAN 2 High | Blue |
ShiftX3 Features
Disco Lights Demo
Script
function rndc()
return math.random(0,255)
for i=0,9,1 do
sxSetDisplay(0, math.random(48,57))
Script
- Default is reading Gear from the channel named "Gear"
setTickRate(30)
-- can bus: 0=CAN1, 1=CAN2
sxSetConfig(0,0,1)
--create gear channel
--config shift light
setChannel(gearId, gear)
sxSetDisplay(0, gear)
Assumptions:
Script
setTickRate(30)
sxSetConfig(0,0,1)
--update RPM
--update engine temp alert
--update oil pressure alert
Script
Boost Gauge
Assumptions
Script
setTickRate(30)
sxSetConfig(0,0,1)
local map = getChannel("MAP")
if map ~= nil then
--convert to PSI boost
sxUpdateLinearGraph(boost)
ShiftX3 CAN bus API
Hardware / CAN configuration
CAN Base Address
| Open | 931584 (0xE3700) |
CAN Baud Rate
| Closed (Default setting) | 500K |
| Open | 1MB |
ShiftX3 CAN Protocol
| Offset | What | Value |
Set Display
CAN ID: Base + 50
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Set Linear Graph Threshold
CAN ID: Base + 41
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 42
| 0 | Value (low byte) | |
| 1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
| 1 | Button ID | ID of button |
