AnalogX
In the kit you will receive:
- AnalogX module
- 4 wire power and CAN pigtail
- 6 wire analog sensor input pigtail
- 1" shrink tube for installation
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Edit the conversion formula
Example: 0.5 - 4.5v 150 PSI oil pressure sensor
0.5v = 0 PSI 4.5v = 150 PSI
Therefore, 150 PSI / 4000mV = 0.0375 PSI/mV, and the resulting formula is RAW * 0.0375 - 18.75
AiM, MoTeC and other systems
No CAN data
- Verify the CAN baud rate is compatible with the AnalogX configuration (500K by default, 1MB with jumper modified)
- Verify your CAN bus termination is correct. AnalogX is terminated by default.
Basic mapping test
| Feature | Description |
| Analog input voltage range | 0 - 5v |
| Pullup resistor | Optional on-board 2.2K pullup resistor for each channel (jumper enabled) |
| Power input | 9 - 15volts, protected to 40v (intermittent) |
| Weight | 6 grams |
| Dimensions | 0.72" x 1.93" (18.3mm x 48.7mm) |
| CAN baud rate | 500K and 1M, jumper configurable |
| Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (jumper configurable) |
Source Code
Power and CAN
| Red | 9-15v Power | Connect this to switched ignition power. 0.25A max consumption. |
| Black | CAN High | |
| Orange | CAN Low | |
| Blue | Ground |
Sensor connections
| Brown | Analog 1 input | 0-5v input |
| Pink | Analog 2 input | 0-5v input |
| Purple | Analog 3 input | 0-5v input |
| Blue | Analog 4 input | 0-5v input |
| Yellow | Voltage reference output | 5v @ 0.5A |
| Black | Ground reference |
CAN termination
AnalogX CAN bus API
Adjusting Base ID
Address
| Offset | What | Value |
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Configuration Group 1
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
| 5 | Reserved | |
| 6 | Reserved | |
| 7 | Reserved |
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
| 0 | Channel 1, low byte | |
| 2 | Channel 2, low byte | |
| 4 | Channel 3, low byte | |
| 6 | Channel 4, low byte | |
| 7 | Channel 4, high byte |
