How To Update Firmware
Firmware upgrade steps
Applies to:
  • RaceCapture/Pro MK3 and MK2
  • RaceCapture/Apex
  • PodiumConnect
  • RaceCapture/Track MK2 and MK1
Save your configuration
Download the firmware
  • Note Ensure you download the correct firmware for your device (matching the product name), or the firmware process will fail to complete.
Flash the firmware
  • Note: Flashing is only possible via the USB interface, so you must use the desktop version of the RaceCapture app.
Steps
Updating Firmware
  • Unzip the firmware your downloaded to a location on your computer.
  • Connect your system to your Windows or OSX computer using the included USB cable.
  • Navigate to the Setup view
  • Browse to the unzipped firmware from the first step. Select the file ending with ".ihex" - and press Open
  • Restore your saved configuration by pressing the Open button, selecting your saved configuration, and then Write it to your system.
Alternative method
  • Navigate to Setup.
  • Load a previously saved configuration file.
  • Navigate to the firmware update view, then follow the process to update firmware.
Issues
If you get an 'Unable to load bootloader' error, try this work around. https://www.youtube.com/watch?v=A-WqZItNB9E
Problems? Post to the forums with the issue you're seeing - we will help you promptly.
RaceCapture/Pro MK1
Alternatively:
Mac Users
