Raspberry Pi Tips
- Choose the fastest MicroSD card you can for fastest boot times. 32gb is plenty big and reasonably cheap. Class 10 is preferred. I used this one:
- On a computer, format the card to FAT32 format
- Download the latest Raspberry Pi Image to the computer
Start Pi and Update OS
- Place the MicroSD card in the Pi, connect a LAN cable to the Pi's Cat5 connection for internet access, connect a keyboard, monitor, (and mouse if you wish), then power up.
- Login: pi
- Password: raspberry
sudo apt-get clean
sudo raspi-config
- Choose Desktop/CLI as Pi
- Choose I1 Change Locale
- Hit enter
sudo nano /boot/cmdline.txt
sudo nano /boot/config.txt
disable_splash=1
Change keyboard to US
cd /opt
sudo tar -xjvf race...
Setup for Mausberry circuit
sudo nano /etc/rc.local
- Reboot to take effect.
sudo reboot
Set up for DFRobot display
- Uncomment this line:
disable_overscan=1
- Add this line:
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_group=2 hdmi_mode=87
- Comment out both checks for "check for ar1100 resistive touch" and "check for ft5406 capacitive touch" by putting a # symbol at the front of the line
- Change kivy settings:
General Notes and Commands
Run Racecapture manually
- If you don't set it up to run automatically, you'll have to use this command to run it manually.
Make cursor visible
- This may cause lag in the dashboard so it's not recommended except for setup if you elect to use a mouse
cursor = 1
Exit RaceCapture
Manually shutdown pi
Sudo Shutdown -h now
Rotate screen 180*
- This just rotates the display, but does not rotate the touch settings
- Add this line:
display_rotate=2
- If you have a touch screen, you will need to rotate the touch settings for RaceCapture
- Modify this line:
- I like to keep the dashboard settings similar between my phone, laptop, and in-dash screen. Once you follow the directions in the link, you can save the config file from RaceCapture to the thumb drive and transfer it between devices. In my experience, this was not a foolproof and reliable solution and required a bit of playing around with it, but it's the easiest solution I found.
