TireX
Revision as of 18:51, 19 March 2020 by Brentp (talk | contribs) (Statistics)
High Performance
Rugged and Compact
Flexible Setup
Orientation can be inverted for consistent data reporting between left and right sides of vehicle. Temperature zones, preferences, and calibration are customizable by the end user. CAN bus can be set for 500 or 1MB.
Feature Description
Sensor type Thermal array
Object temperature range -40 - 200C
Field of view 120 degrees
Accuracy 1C
Temperature zones 1 / 2 / 4 / 8 / 16
Sample rate 0.5 - 64Hz
Processing Engine 32 bit
Temperature compensation Automatic
Electrical
Interface CAN 2.0
Supply voltage 6 - 12v
Power 200mW
Address space 4 separate address spaces (jumper configurable)
Termination No Termination (jumper configurable)
Physical / Environmental
Dimensions 64 x 46 x 12.5mm
Weight 10 grams
Operating temperature -40 to 85C
IP rating IP65
CAN bus protocol
A configured TireX sensor will have a CAN base address that is a combination of the Main Base ID + Position Offset based on the installed position of the sensor on the vehicle. This combination creates a final Sensor Base ID
Default Main Base ID
Adjusting Main Base ID
Closed Closed 0xA100 (41216)
Closed Open 0xB100 (45312)
Open Closed 0xC100 (49408)
Open Open 0xD100 (53504)
Sensor Position Offset
The sensor position will offset the Main Base ID by the position of the sensor as defined in the table, to set the final Sensor Base ID
0 Left-Front 0x0 (0)
1 Right-Front 0x100 (256)
2 Left-Rear 0x200 (512)
3 Right-Rear 0x300 (768)
Left-Front 0xA100
Right-Front 0xA200
Left-Rear 0xA300
Right-Rear 0xA400
Address
CAN ID: Sensor Base ID + 0
0 Sample Rate unsigned A * 1 Sample Rate (Hz)
3 Reserved
4 Reserved
Configuration Preferences
Address
CAN ID: Sensor Base ID + 3
0 Sample Rate unsigned A * 1 Rate to report sensor values ( 0.5 - 64Hz). Valid sample rates: 0 (0.5Hz) / 1 (1Hz) / 2 (2Hz) / 4 (4Hz) / 8 (8Hz) / 16 (16Hz) / 32 (32Hz) / 64 (64Hz).
2 Sensor Position unsigned A * 1 Location of the sensor on the vehicle. This position adjusts the Sensor Base ID. Valid Positions 0 (Left-Front) / 1 (Right-Front) / 2 (Left-Rear) / 3 (Right-Rear).
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Calibration Preferences
Address
CAN ID: Sensor Base ID + 4
0 Emissivity unsigned A * 100 Emissivity of the target. Default is 0.95
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
CAN ID: Sensor Base ID + 2
0 Current Sample Rate unsigned A * 1 0.5 - 64Hz (0 = 0.5Hz)
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sensor Value Broadcast
1 Zone
0 Zone 1 value unsigned A - 40 Degrees C
2 Zones
1 Zone 2 value unsigned A - 40 Degrees C
4 Zones
2 Zone 3 value unsigned A - 40 Degrees C
3 Zone 4 value unsigned A - 40 Degrees C
8 Zones
4 Zone 5 value unsigned A - 40 Degrees C
5 Zone 6 value unsigned A - 40 Degrees C
6 Zone 7 value unsigned A - 40 Degrees C
7 Zone 8 value unsigned A - 40 Degrees C
16 Zones
0 Zone 9 value unsigned A - 40 Degrees C
1 Zone 10 value unsigned A - 40 Degrees C
2 Zone 11 value unsigned A - 40 Degrees C
3 Zone 12 value unsigned A - 40 Degrees C
4 Zone 13 value unsigned A - 40 Degrees C
5 Zone 14 value unsigned A - 40 Degrees C
6 Zone 15 value unsigned A - 40 Degrees C
7 Zone 16 value unsigned A - 40 Degrees C
