TireX
Upcoming Product
TireX pre-orders are starting soon: sign up to get notified when pre-orders launch
High Performance
Rugged and Compact
Flexible Setup
- CAN bus can be set for 500 or 1MB (default is 500K)
Feature | Description |
Sensor type | Thermal array |
Object temperature range | 0 - 127.5C (-40 - 300C range available via special order) |
Field of view | 120 degrees |
Accuracy | 1C |
Temperature zones | 1 / 2 / 4 / 8 / 16 |
Sample rate | 0.5 - 64Hz |
Processing Engine | 32 bit |
Configurable positions | 4 (Left-Front, Right-Front, Left-Rear, Right-Rear); Reversible orientation |
Temperature compensation | Automatic |
Electrical | |
Interface | CAN 2.0 |
Supply voltage | 6 - 12v |
Power | 200mW |
CAN bus | |
CAN baud rate | 500K and 1M, jumper configurable (500K default) |
Physical / Environmental | |
Construction | CNC aluminum |
Weight | 10 grams |
IP rating | IP65 |
Dimensions / Mounting
Electrical / CAN connection
Pin | Connecton |
Pin 1 | CAN Low |
Pin 2 | Voltage supply (6-12v) |
Pin 3 | CAN High |
Pin 4 | Ground |
Zone Configuration
When configured for 2 or more zones, temperature for zones are reported in the order of inside through outside edge. TireX zones are reversed based on the configured sensor position (left vs right side) to allow identical physical sensor mounting orientation between sides.
Zones | Coverage |
CAN bus protocol
Formula
- Example:
- Formula: A / 100
- Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value | Symbol Reference |
8 Bit values | A |
Default Main Base ID
Adjusting Main Base ID
Sensor Position Offset
0 | Left-Front | 0x0 (0) |
2 | Left-Rear | 0x200 (512) |
Left-Front | 0xA100 |
Right-Front | 0xA200 |
Left-Rear | 0xA300 |
Right-Rear | 0xA400 |
CAN ID: Sensor Base ID + 0
1 | Temperature Zones | unsigned | A * 1 | Number of configured temperature zones (1 / 2 / 4 / 8 / 16) |
3 | Reserved | |||
4 | Reserved | |||
CAN ID: Sensor Base ID + 2
0 | Current Sample Rate | unsigned | A * 1 | 0.5 - 64Hz (0 = 0.5Hz) |
1 | Reserved | |||
2 | Reserved | |||
3 | Reserved | |||
4 | Reserved | |||
Configuration Preferences
CAN ID: Sensor Base ID + 3
2 | Sensor Position | unsigned | A * 1 | Location of the sensor on the vehicle. This position adjusts the Sensor Base ID. Valid Positions 0 (Left-Front) / 1 (Right-Front) / 2 (Left-Rear) / 3 (Right-Rear). Specifying an invalid value will select the default value of 0 (Left-Front). Note: The sensor position affects the orientation of the sensor zones. Sensor Position 1 and 3 will report temperature zones left - right; Position 0 and 2 will report temperature zones right - left. |
3 | Reserved | |||
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
Calibration Preferences
CAN ID: Sensor Base ID + 4
1 | Reserved | |||
2 | Reserved | |||
3 | Reserved | |||
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
Sensor Value Broadcast
The following messages will contain the temperature values based on the number of temperature zones selected.
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
