TireX
Upcoming Product
TireX pre-orders are starting soon: sign up to get notified when pre-orders launch
High Performance
Rugged and Compact
Flexible Setup
- CAN bus can be set for 500 or 1MB (default is 500K)
| Feature | Description |
| Object temperature range | 0 - 127.5C (-40 - 300C range available via special order) |
| Field of view | 120 degrees |
| Accuracy | 1C |
| Temperature zones | 1 / 2 / 4 / 8 / 16 |
| Sample rate | 0.5 - 64Hz |
| Configurable positions | 4 (Left-Front, Right-Front, Left-Rear, Right-Rear); Reversible orientation |
| Temperature compensation | Automatic |
| Electrical | |
| Interface | CAN 2.0 |
| Supply voltage | 6 - 12v |
| Power | 200mW |
| CAN bus | |
| CAN baud rate | 500K and 1M, jumper configurable (500K default) |
| Weight | 10 grams |
| IP rating | IP65 |
Dimensions / Mounting
Electrical / CAN connection
| Pin | Connecton |
| Pin 1 | CAN Low |
| Pin 2 | Voltage supply (6-12v) |
| Pin 3 | CAN High |
| Pin 4 | Ground |
Zone Configuration
| Zones | Coverage |
CAN bus protocol
Formula
- Example:
- Formula: A / 100
- Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
| Value | Symbol Reference |
| 8 Bit values | A |
Default Main Base ID
Adjusting Main Base ID
Sensor Position Offset
| 0 | Left-Front | 0x0 (0) |
| Left-Front | 0xA100 |
| Right-Front | 0xA200 |
| Left-Rear | 0xA300 |
| Right-Rear | 0xA400 |
CAN ID: Sensor Base ID + 0
| 1 | Temperature Zones | unsigned | A * 1 | Number of configured temperature zones (1 / 2 / 4 / 8 / 16) |
| 3 | Reserved | |||
| 4 | Reserved | |||
CAN ID: Sensor Base ID + 2
| 0 | Current Sample Rate | unsigned | A * 1 | 0.5 - 64Hz (0 = 0.5Hz) |
| 1 | Reserved | |||
| 2 | Reserved | |||
| 3 | Reserved | |||
| 4 | Reserved | |||
Configuration Preferences
CAN ID: Sensor Base ID + 3
| 2 | Sensor Position | unsigned | A * 1 | Location of the sensor on the vehicle. This position adjusts the Sensor Base ID. Valid Positions 0 (Left-Front) / 1 (Right-Front) / 2 (Left-Rear) / 3 (Right-Rear). Specifying an invalid value will select the default value of 0 (Left-Front). Note: The sensor position affects the orientation of the sensor zones. Sensor Position 1 and 3 will report temperature zones left - right; Position 0 and 2 will report temperature zones right - left. |
| 3 | Reserved | |||
| 4 | Reserved | |||
| 5 | Reserved | |||
| 6 | Reserved | |||
| 7 | Reserved |
Calibration Preferences
CAN ID: Sensor Base ID + 4
| 1 | Reserved | |||
| 2 | Reserved | |||
| 3 | Reserved | |||
| 4 | Reserved | |||
| 5 | Reserved | |||
| 6 | Reserved | |||
| 7 | Reserved |
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
