MJLJ V4 kit assembly guide
Revision as of 16:11, 8 June 2008 by Brentp (talk | contribs) (1st checkpoint)
Precautions
Surface mount Components
Before you Begin
Familiarize
Do not lose parts
Lighting
Use lots of good lighting- best is to use bright overhead lights combined with an illuminated magnifying glass.
Note part orientation
Do not overheat
Small parts are easy to damage- use minimal heat required for soldering components. It is essential a recommended low wattage, fine-tipped soldering iron be used for assembly.
Assembling the kit
Tools you will need
