Standard CAN broadcast
Revision as of 01:19, 8 September 2020 by Brentp (talk | contribs) (→Timing and Scoring integration)
Standard CAN broadcast for RaceCapture and PodiumConnect
The following describes the standardized broadcast messages for RaceCapture and PodiumConnect devices.
  • Byte ordering: Little Endian
Alert Messages
This describes the CAN format for Pit to Car alert messages.
Messages are broadcasted in ASCII character format, with a maximum of 16 characters across two CAN messages.
Alert Messages are broadcast on CAN1.
Message priority is 0 - 2, with 0 = normal priority used for pit-to car alerts, and 1 - 2 reserved for future use.
Base address: 0xA100 (41216)
Address for message is calculated by the base address offset by priority:
  • Priority 0 address: 0xA100 (41216) / 0xA101 (41217)
  • Priority 1 address: 0xA102 (41218) / 0xA103 (41219)
  • Priority 2 address: 0xA104 (41220) / 0xA105 (41221)
CAN ID Byte 0 1 2 3 4 5 6 7
Base Address message character 0 1 2 3 4 5 6 7
Base Address + 1 message character 8 9 10 11 12 13 14 15
CAN broadcast mapping for timing and scoring integration.
This broadcast is enabled with the Lua script provided by the Timing and scoring CAN broadcast script preset.
Base address: 0xA200 (41472)
CAN ID What Offset Length Formula Units Notes
0xA200 (41472) Last Timing & Scoring lap time 0 2 * .001 + 0.0 min. Last lap time as reported by timing and scoring system
0xA200 (41472) Position Overall 2 1 * 1 + 0
0xA200 (41472) Position in Class 3 1 * 1 + 0
0xA200 (41472) Competitor Number Ahead 4 2 * 1 + 0
0xA200 (41472) Competitor Number Behind 6 2 * 1 + 0
0xA201 (41473) Gap to Competitor Ahead 0 2 * 0.1 + 0.0 sec. Value will be zero if gap is 1 lap or greater
0xA201 (41473) Gap to Competitor Behind 2 2 * 0.1 + 0.0 sec. Value will be zero if gap is 1 lap or greater
0xA201 (41473) Laps to Competitor Ahead 4 1 * 1 + 0
0xA201 (41473) Laps to Competitor Behind 5 1 * 1 + 0
0xA201 (41473) Full Course Flag state 6 1 * 1 + 0 0=None; 1=Green; 2=Yellow; 3=Red; 4=Finish
0xA201 (41473) Competitor Flag State 7 1 * 1 + 0 0=no flag; 1=Black Flag
