AnalogX2
In the kit you will receive:
  • AnalogX2 module
Harness / Cabling
SKU Description
ASL_M8_CAN_EXT_0.5M
ASL_M8_CAN_EXT_1M
ASL_M8_CAN_EXT_2M
ASL_M8_CAN_EXT_3M
ASL_M8_CAN_EXT_4M
CAN extension cable, M8 4P female to M8 4P male, 0.5 - 4 Meter lengths
Sensor Connections
SKU Description
ASL_M8_SENSOR_EXTENSION_1M
ASL_M8_SENSOR_EXTENSION_2M
ASL_M8_SENSOR_EXTENSION_3M
ASL_M8_SENSOR_EXTENSION_4M
Bare pigtails
For a custom or non-plug and play installation, these bare pigtail cables are available:
SKU Description
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
  • 0.5v 0 bar / = 0 PSI
  • 4.5v = 10 bar / 150 PSI
Therefore,
  • Note:: The 0.375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
  • 0.5v = 0 bar / 0 PSI
  • 4.5v = 150 bar / 2175 PSI
Other sensors
No CAN data
Basic mapping test
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Weight 5 oz (approximately)
Environmental IP65 rated, 0-85C
Power and CAN
Pin Connection Notes
1 CAN low
2 Power Red, 12-14v / 50mA
3 CAN high
4 Ground Black
Sensor connections
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
CAN termination
AnalogX CAN bus API
Adjusting Base ID
Off Off 0xE4600 (935424)
Off On 0xE4700 (935680)
On Off 0xE4800 (935936)
On On 0xE4900 (936192)
1M is enabled by default; switch on the Baud DIP swith to enable 500K data rate.
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
