AnalogX2
In the kit you will receive:
- AnalogX2 module
Harness / Cabling
SKU | Description |
ASL_DUAL_CAN_HUB | Powered, 8 port dual CAN bus hub kit |
ASL_M8_CAN_EXT_0.5M ASL_M8_CAN_EXT_1M ASL_M8_CAN_EXT_2M ASL_M8_CAN_EXT_3M ASL_M8_CAN_EXT_4M |
CAN extension cable, M8 4P female to M8 4P male, 0.5 - 4 Meter lengths |
Sensor Connections
SKU | Description |
ASL_4X_SENSOR_SPLITTER | 4X sensor expander |
ASL_M8_SENSOR_EXTENSION_1M ASL_M8_SENSOR_EXTENSION_2M ASL_M8_SENSOR_EXTENSION_3M ASL_M8_SENSOR_EXTENSION_4M |
ASL_LINEAR_TEMP_M8 | Linear temperature sensor |
ASL_10_BAR_DELPHI3_M8 | 10 bar (150 PSI) pressure sensor |
ASL_150_BAR_DELPHI3_M8 | 150 bar (2175 PSI) pressure sensor |
ASL_M8_SENSOR_PIGTAIL_2M | Single sensor pigtail for custom sensor connection, 2 Meters |
Bare pigtails
For a custom or non-plug and play installation, these bare pigtail cables are available:
SKU | Description |
ASL_DEVICE_CAN_PIGTAIL_1M | CAN + power pigtail for connecting device, M8 4P male to bare wires, 1 meter |
ASL_M8_QUAD_SENSOR_PIGTAIL_2M | M8 8P male to bare wire quad sensor pigtail, 1M, 24AWG |
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
- 0.5v 0 bar / = 0 PSI
- 4.5v = 10 bar / 150 PSI
Therefore,
- Note:: The 0.375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
- 0.5v = 0 bar / 0 PSI
- 4.5v = 150 bar / 2175 PSI
Other sensors
Power and CAN
- Connector: M8 4P Male, A coding
Pin | Connection | Notes |
1 | CAN low | |
2 | Power | Red, 12-14v / 50mA |
3 | CAN high | |
4 | Ground | Black |
Sensor connections
1 | Analog/Digital 1 | |
2 | Analog/Digital 2 | |
3 | Analog/Digital 4 | |
5 | Ground | |
7 | Analog/Digital 3 | |
8 | Ground |
- Note: The AnalogX inputs are very high impedance, allowing connection to existing circuits / sensors without affecting the reading of that circuit. As such, no pull-up or pull-down resistors are provided and must be added externally if needed.
DIP switch settings
Switch | Function | Description |
1 | Termination | Set to ON to enable CAN termination |
2 | Address offset 1 | Used to select the base CAN address |
3 | Address offset 2 | Used to select the base CAN address |
4 | CAN Baud Rate | OFF to enable 1M (default), ON to enable 500K |
CAN termination
No CAN data
Basic mapping test
Feature | Description |
Analog sensor input voltage range | 0 - 5v |
DAC resolution | 12 bit SAR |
Sample output format | 0 - 5000mV |
Input impedance | Greater than 10 Meg Ohm |
Input voltage protection | 100v |
CAN baud rate | 1M and 500K, jumper configurable |
Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (DIP switch configurable) |
Power input and connections | 9 - 15volts, protected to 40v (intermittent) |
Harness | M8 4P Male for power + ground, M8 8P for sensor connection |
Weight | 5 oz (approximately) |
Dimensions | 60 x 60 (approximately) |
Environmental | IP65, 0-85C |
AnalogX CAN bus API
Adjusting Base ID
- Switching on ADR1 will add 256 to the base ID
- Switching on ADR2 will add 512 to the base ID.
ADR2 switch | ADR1 switch | Address |
Off | Off | 0xE4600 (935424) |
Off | On | 0xE4700 (935680) |
On | Off | 0xE4800 (935936) |
On | On | 0xE4900 (936192) |
1M is enabled by default; switch on the Baud DIP swith to enable 500K data rate.
Address
Offset | What | Value |
0 | Channel Count | Total number of channels on device |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Major Version | Firmware Major Version Number |
6 | Minor Version | Firmware Minor Version Number |
7 | Patch Version | Firmware Patch version number |
Configuration Group 1
Address
0 | Sample Rate | Rate to report sensor values ( 1 - 255Hz). Default sample rate is 50Hz. |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Reserved | |
6 | Reserved | |
7 | Reserved |
Address
0 | Current Sample Rate | 1 - 255Hz |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
0 | Channel 1, low byte | |
1 | Channel 1, high byte | |
2 | Channel 2, low byte | |
3 | Channel 2, high byte | |
4 | Channel 3, low byte | |
5 | Channel 3, high byte | |
6 | Channel 4, low byte | |
7 | Channel 4, high byte |
