Raspberry Pi Tips
Revision as of 04:34, 9 November 2021 by Brentp (talk | contribs) (Rotate screen 180*)
  • Open the console based raspi-config application:
sudo raspi-config
  • Choose Desktop/CLI as Pi
  • Highlight #4 Localisation Options and hit enter. I live in the Eastern Timezone of the US - customize these selections to your location.
    • Choose I1 Change Locale
    • Hit enter
sudo nano /boot/cmdline.txt
  • Inside this file, append the following to the end of the line:
sudo nano /boot/config.txt
disable_splash=1
Change keyboard to US
cd /opt
sudo tar -xjvf race...
Setup for Mausberry circuit
sudo bash carsetup.sh
sudo reboot
sudo nano /etc/rc.local
  • Reboot to take effect.
sudo reboot
Set up for DFRobot display
  • Uncomment this line:
disable_overscan=1
  • Add this line:
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_group=2
hdmi_mode=87
Cd /opt/racecapture/
Sudo nano run_racecapture.sh
  • Comment out both checks for "check for ar1100 resistive touch" and "check for ft5406 capacitive touch" by putting a # symbol at the front of the line
  • Change kivy settings:
[input]
mouse = mouse
General Notes and Commands
Run Racecapture manually
  • If you don't set it up to run automatically, you'll have to use this command to run it manually.
Make cursor visible
  • This may cause lag in the dashboard so it's not recommended except for setup if you elect to use a mouse
cursor = 1
Exit RaceCapture
To kill the watchdog loop until the next restart, you can use the following command:
 killall -9 run_racecapture.sh
Manually shutdown pi
Sudo Shutdown -h now
Manually restart PI
 sudo reboot
Rotate screen 180*
  • This just rotates the display, but does not rotate the touch settings
  • Add this line (if HDMI)
display_rotate=2
  • Add this line (if Official LCD screen)
lcd_rotate=2
  • If you have a touch screen, you will need to rotate the touch settings for RaceCapture
  • Modify this line:
  • I like to keep the dashboard settings similar between my phone, laptop, and in-dash screen. Once you follow the directions in the link, you can save the config file from RaceCapture to the thumb drive and transfer it between devices. In my experience, this was not a foolproof and reliable solution and required a bit of playing around with it, but it's the easiest solution I found.
