MJLJ V4 kit assembly guide
Revision as of 07:49, 11 June 2008 by Brentp (talk | contribs) (→‎Components: added images)
Precautions
Surface mount Components
Before you Begin
Familiarize
Do not lose parts
Lighting
Note part orientation
Do not overheat
Assembling the kit
Tools you will need
Parts Inventory
Core Parts
Part Type Value Photo
Enclosure MJLJ V4 Enclosure File:MJLJ V4 enclosure.jpg
U1 Integrated Circuit MJLJ V4 Processor Freescale MC908QB8 File:MC908QB8.jpg
IC1 Integrated Circuit ULN2003 Transistor Array File:ULN2003.jpg
U2 Integrated Circuit MAX232A Transceiver (or equivalent) File:MAX232a.jpg
IC1,U1 Sockets 16 Pin DIP Socket File:PDIP-16 socket.jpg
X1 Connector RJ-11 jack File:RJ11 jack.jpg
X2 Connector Molex Right angle, 16 position Molex minifit 16 right angle pcb.jpg
TPS Option
MAP Sensor Option
PS1 Sensor MPX4250ap File:MPX4250ap.jpg
Surface Mount Parts
Power supply Circuit
Prepare solder pads
Components
  • D4: 12V Zener diode. Note stripe orientation: The silk-screened arrow on the PC board points towards the stripe.
If you have difficulty identifying them, increase the lighting- bright lighting is essential.
  • R9: 680 ohm resistor
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Main Circuit
Prepare Solder Pads
Components
  • D6,D7: Schottky diode (strip of two diodes, SOD-123 package SOD-123.jpg
MAP sensor option
  • C9,C8: 0.1uF capacitor (strip of 6 capacitors, ORANGE stripe on tape)
TPS option
  • D5: Schottky Diode (strip of one diode, SOD-123 package SOD-123.jpg)
  • C14: 15uF capacitor (grey tantalum package)
  • L1: 1uH inductor (strip of one inductor, 1210 package: 1210 smt inductor.jpg)
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Through Hole Parts
IMPORTANT: It extremely important you install the through-hole components with the correct orientation! De-soldering a backwards-installed component is extremely difficult and will likely damage the board. GET IT RIGHT THE FIRST TIME!
Install Components
You may need to re-heat the pad while squeezing the part against the board. Once your
If not perfect, re-heat solder near the corner affected and correct the connector's position.
MAP Sensor Option
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Installing ICs
Install U1- MJLJ V4 Processor Freescale MC908QB8. Note notch orientation Install IC1- ULN2003 transistor array Note notch orientation
Final Inspection
Solder joints
Carefully check the top and bottom of board for solder joint quality- all joints should be bright and shiny, minimal blobbing, no solder 'spikes', bridges. Also look for missed solder joints!
Part placement
Ensure all through hole components are flush
TIP: An illuminated magnifying glass is great for getting an up-close inspection of your work
Enclosure installation
TIP: the molex connector is slightly off-center, so it's easier to use install the plate with the board installed first.
Testing
Verification on the bench
Next Steps
