Revision as of 00:02, 8 February 2023 by Brentp (talk | contribs)
Install ubuntu 22.x
  • Select Automatic Login without password
Disable keyring popup
Disable the keyring popup
Install dependencies
sudo apt-get install v4l-utils tk gstreamer1.0-plugins-bad gstreamer1.0-libav
Enable access to RaceCapture serial port
sudo adduser $USER dialout
sudo echo "ATTRS{idVendor}==16d0, ATTRS{idProduct}==07f1, MODE=0666" | sudo tee /etc/udev/rules.d/70-autosportlabs.racecapture.rules
Hide Ubuntu Top bar
Hide top bar
Hide side bar
sudo apt install gnome-shell-extensions
Now run extensions tool, set Ubuntu Dock -> OFF
Download the latest RaceCapture app for Linux
http://podium.live/software
Disable system update notification poupup
gconftool -s --type bool /apps/update-notifier/auto_launch false
Extract the RaceCapture app archive
tar -xzf <downloaded filename>
Launch RaceCapture app
./run_racecapture_linux.sh
Enable fullscreen mode & Default dashboard mode
  • Go to Setup / App Preferences
  • set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
