Revision as of 22:34, 8 February 2023 by Brentp (talk | contribs)
Setup
Install ubuntu 22.x
  • Select Automatic Login without password
Disable keyring popup
Disable the keyring popup
Run the installer
do it
Enable fullscreen mode & Default dashboard mode
  • Go to Setup / App Preferences
  • set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
