Setup
Install ubuntu 22.x
- Select Automatic Login without password
Disable keyring popup
Run the installer
do it
Enable fullscreen mode & Default dashboard mode
- Go to Setup / App Preferences
- set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Maintenance/Troubleshooting
Open a terminal window
- Press ctrl+t then c
Log out
You can log out of the current session to access the original Ubuntu desktop.
- Press ctrl_t then :
- Then type 'quit' and press <enter>
Once you've logged out, you can log back into the Ubuntu desktop by pressing the gear icon in the lower right and select Ubuntu.
To get back to the RaceCapture full-screen app mode, select "Ratpoison" from this menu - this is the window manager that is configured to run RaceCapture in full-screen mode.
