Setup
Install ubuntu 22.x
- Select Automatic Login without password
Disable keyring popup
Run the installer
Enable fullscreen mode & Default dashboard mode
- In the RaceCapture app, go to Setup / App Preferences
- set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
TODO: update this section with information on configuring the youtube streaming key, etc.
Video will be recorded in the user's home Video directory.
Maintenance/Troubleshooting
Open a terminal window
- Press ctrl+t then c
Log out
You can log out of the current session to access the original Ubuntu desktop for additional maintenance.
- Press ctrl_t then :
- Type 'quit' and press <enter>
To get back to the RaceCapture full-screen app mode, select "Ratpoison" from this menu; this is the window manager that is configured to run RaceCapture in full-screen mode.
