Setup
Install ubuntu 22.x
  • Select Automatic Login without password
Disable keyring popup
Disable the keyring popup
Run the installer
Reboot
Reboot the computer. It should automatically launch the RaceCapture app.
Edit RaceCapture settings
App Preferences
In the RaceCapture app, go to Setup / App Preferences:
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
Go to Dashboard, then press the gear icon in the upper right of the dashboard. Touch More Settings
  • Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture]
audio_device=1
[local_recording]
video_dir=$HOME/Videos
[streaming]
Maintenance/Troubleshooting
Open a terminal window
  • Press ctrl+t then c
Log out
  • Press ctrl_t then :
