Parts you will need
The RaceCapture system will provide access to your car's sensor data (CAN bus or analog sensors), high performance GPS, Accelerometer / Gyro sensors, and also compute lap timing and other motorsport related functions.
Compatible Systems
  • Any existing RaceCapture system will work.
Micro computer system
The micro computer will be responsible for rendering video + data, encoding, and broadcasting the video to youtube or similar streaming platform.
Recommended
Alternatives
A micro system with Intel I5-6500 through I5-7600 with SSD and 8GB RAM is an acceptable option as well, and a system you may already have or can get for free.
  • Look for these options:
  • * SSD (required for ruggedness - smallest size is fine).
  • * Smallest RAM option is fine (typically 8GB)
  • * Included WiFi - for connection versatility
Candidates
Setup
Install ubuntu 22.x
  • Select Automatic Login without password
Disable keyring popup
Disable the keyring popup
Run the installer
Reboot
Reboot the computer. It should automatically launch the RaceCapture app.
Edit RaceCapture settings
App Preferences
In the RaceCapture app, go to Setup / App Preferences:
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
Go to Dashboard, then press the gear icon in the upper right of the dashboard. Touch More Settings
  • Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture]
audio_device=1
[local_recording]
video_dir=$HOME/Videos
[streaming]
Maintenance/Troubleshooting
Open a terminal window
  • Press ctrl+t then c
Log out
  • Press ctrl_t then :
