Parts you will need
Compatible Systems
  • Any existing RaceCapture system will work.
Micro computer system
The micro computer will receive data from RaceCapture and is responsible for rendering video+data, encoding, and broadcasting the video to youtube or similar streaming platform.
Recommended
Alternatives
A micro system with an Intel I5-6500 through I5-7600 + SSD + 8GB RAM is an acceptable option as well. This may be a system you already have or can get surplus for a minimal cost.
  • Look for these options:
Candidates
12v DC to DC converter
  • Tips:
Recommended
  • KFD 100W universal car charger
  • Notes:
Cameras
Recommended
Alternatives
  • Tips:
Microphone
  • Candidates:
Hotspot/Router
Most any hostspot should work, but for the very best performance and reliability, these options should be considered:
Setup
Connect a keyboard, mouse, and monitor to the rendering/streaming computer and install Ubuntu.
Install ubuntu 22.x
Disable keyring popup
From the desktop, choose log out, and log back in with the password you created during the installation step.
  • Note: Disabling the keyring is important to prevent a popup dialog when the RaceCapture app automatically starts.
Run the installer
Reboot
Edit RaceCapture settings
App Preferences
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
  • Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture]
audio_device=1
[local_recording]
video_dir=$HOME/Videos
[streaming]
Maintenance/Troubleshooting
Open a terminal window
  • Press ctrl+t then c
Log out
  • Press ctrl_t then :
