- Rich graphics overlay in realtime
- Local video recording
Cost
How hard is it to setup?
- Typing computer commands
- Plugging in cables
- Editing configuration files
Parts you will need
Compatible Systems
- Any existing RaceCapture system will work.
Micro computer system
The micro computer will receive data from RaceCapture and is responsible for rendering video+data, encoding, and broadcasting the video to youtube or similar streaming platform.
Recommended
Alternatives
A micro system with an Intel I5-6500 through I5-7600 + SSD + 8GB RAM is an acceptable option as well. This may be a system you already have or can get surplus for a minimal cost.
- Look for these options:
Candidates
- Dell Optiplex 7050 micro desktop: Ebay search
12v DC to DC converter
- Tips:
Recommended
- KFD 100W universal car charger
- Notes:
Cameras
Recommended
Alternatives
- Tips:
Microphone
- Candidates:
Hotspot/Router
Most any hostspot should work, but for the very best performance and reliability, these options should be considered:
Setup
Connect a keyboard, mouse, and monitor to the rendering/streaming computer and install Ubuntu.
Install ubuntu 22.x
- Install Ubuntu with the following options:
- During installation, choose the option to download / install updates, including "non-free" software updates (which includes video drivers)
- Select Automatic Login without password.
Disable keyring popup
From the desktop, choose log out, and log back in with the password you created during the installation step.
- Note: Disabling the keyring is important to prevent a popup dialog when the RaceCapture app automatically starts.
Run the installer
Reboot
Edit RaceCapture settings
App Preferences
- set Fullscreen -> ON
- Turn off Session Recording
Dashboard Preferences
- Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture] audio_device=1 [local_recording] video_dir=$HOME/Videos [streaming] streaming_url=rtmp://a.rtmp.youtube.com/live2/<streaming key>
Maintenance/Troubleshooting
Open a terminal window
- Press ctrl+t then c
Log out
- Press ctrl_t then :
- Type 'quit' and press <enter>
