- Local video recording
System Overview
Cost
How hard is it to setup?
- Typing computer commands
- Plugging in cables
- Editing configuration files
Production State
A demonstration
Experimental
Parts you will need
Compatible Systems
Rendering/Streaming computer
Recommended
Alternatives
- Look for these options:
Candidates
12v DC to DC converter
- Tips:
Recommended
- Tips:
Cameras
Autosport Labs will soon provide a camera kit that provides high quality imaging, a waterproof compact form-factor, and the perfect 90 degree field of view.
Alternatives
- Tips:
Microphone
- Candidates:
Display Emulator
- HDMI emulator - use this for the Beelink Micro PC
- DisplayPort emulator - use this for the HP or Dell Micro PCs
Hotspot/Router
Setup
Install ubuntu 22 LTS
OS configuration options
- Important - Install Ubuntu with the following options
- During installation, choose the option to download / install updates, including "third-party software for graphics, WiFi, and additional media formats"
- Select Login Automatically
Disable keyring popup
- Notes
- Disabling the keyring is important; it prevents a popup dialog when the RaceCapture app automatically starts.
Run the installer
sudo apt install curl curl -sL bit.ly/3RL9Yoj | bash
Reboot
Edit RaceCapture settings
App Preferences
- set Fullscreen -> ON
- Turn off Session Recording
Dashboard Preferences
- Turn off Pit stop timer
- Turn off pit-to-car alerts
Plug in camera(s)
Plug in USB microphone
Connect RaceCapture
Via USB (overall best option)
Via WiFi
Configure as Client
Create a test dashboard
Exiting the RaceCapture app
Video Streaming / recording
Streaming Key / URL
Local recording
Video files will also be saved in the user's Videos directory
Microphone
- Note, you can change this to different sources:
- 0 = microphone connected to built-in headset port;
- 1,2,3... = represents additional microphones found on the system, typically USB microphones.
Example default config file
[capture] audio_device=1 [local_recording] video_dir=$HOME/Videos [streaming] streaming_url=rtmp://a.rtmp.youtube.com/live2/<streaming key>
First Test
Maintenance/Troubleshooting
Open a terminal window
- Press ctrl+t, then type c, then press <enter>
- Note: The more user-friendly alternative is to just log out and log back in to the Ubuntu desktop.
Log out
- Press ctrl-t, then type :quit, then press <enter>
Inspecting Logfiles
Video streamer log file
RaceCapture log file
Extras
Mount for Beelink micro PC
- Download STL file for 3D printing: File:Beelink SER5 mount.zip
