RaceCapture-Pro MK4S Sensors
Delphi-Style
This is -40 to 150C Linear temperature sensor with plug and play harness. The specification of the sensor are as follows.
  • Connection Size : 1/8″ NPT
  • Cable length : 1 Meter
  • Voltage supply : 3-5V
Pressure Sensors
Pulse/Speed/RPM Sensors
Distance Sensors
Angle/Rotation Sensors
Air / Fuel Ratio Sensors
Wiring Analog Sensors
