Legacy Products
Revision as of 15:40, 9 January 2026 by Brentp (talk | contribs)
RaceCapture/Apex
RaceCapture/Apex is a pro-motorsports grade real-time telemetry system with mission-critical features. For more details, please click on the image below.
RaceCapture/Pro Mk3
RaceCapture/Pro MK3 is motorsports telemetry system, packed with features for Endurance Racing, Sprint Racing, Autocross, Time Attack and more. For more details, please click on the image below.
RaceCapture/Pro MK2
RaceCapture/Pro MK2 is a motorsports telemetry system designed for precision performance analytics and real-time data streaming to elevate your racing strategy. For more details, please click on the image below.
RaceCapture/Pro MK1
RaceCapture/Pro MK1 is also a a powerful, multi-channel data acquisition and control system for motorsport applications. For more details, please click on the image below.
RaceCapture/Track MK3
RaceCapture/Track MK2
The RaceCapture-Track MK2 is a data logger, lap timer, and gauge system for race or street cars. It is ultra-compact and has OBDII and direct CAN integration to almost any sensor or ECU. For more details, please click on the image below.
RaceCapture/Track MK1
The RaceCapture/Track MK1 is a compact and powerful data acquisition system specifically designed for the grassroots racer and track day enthusiasts. It offers essential features to capture and analyze vehicle and driver performance, designed with affordability and ease of use in mind. For more details, please click on the image below.
AnalogX 4 channel analog to CAN bus I/O exapnder
AnalogX is a compact and lightweight 4 channel Analog to CAN I/O expander, designed to be installed in-line with your wiring harness and specially designed for the harsh automotive electrical environment. For more details, please click on the image below.
ShiftX2 RGB Sequential Shift light and alerts
The ShiftX2 is a sequential shift light and sensor alert module that is controlled by RaceCapture over CAN bus. It can monitor critical sensors, visualize predictive lap times, and customize alarms. It’s your light to use the way you want to!. For more details, please click on the image below.
OBD2CAN OBDII Legacy Adapter (RJ45 cable style)
The OBD2CAN OBDII Legacy Adapter translates your car's legacy OBDII interface into a CAN OBDII interface, transparently - effectively modernizing your car's OBDII interface. For more details, please click on the image below.
