RacecapturePro MK4 hardware install
Mounting Orientation
Recommended Orientation
Alternate Orientations
  • Upside Down
  • Vertical / On Edge
Calibration and Remapping
Mounting Dimensions
  1. 12-pin female M12 connector for analog input devices.
  2. SMA connector for GPS antenna connection.
  3. 12-pin female M12 connector for digital input and RPM sensors.
  4. 6-pin female M8 connector for CAN1, CAN2, and power connections.
  5. 4-pin female M8 connector for CAN1 and power connections.
M12 Analog / Digital Connectors
M12 Analog / Digital ConnectorsCaption text
6 Vref 5v @ 0.5A 5v @ 0.5A
9 Analog/Digital B Analog 7 GPIO 3
10 Ground
11 Ground
12 Ground
M8 Connectors 4-Pin CAN1+Power
Pin Connection Notes
1 CAN 1 low
2 Power 9-24v / 1A (~12W)
3 CAN 1 high
4 Ground
1 CAN 1 low
2 CAN 2 low
3 CAN 2 high
4 Ground
5 CAN 1 high
6 Power 9-24v / 1A (~12W)
OBDII CAN cable
SMA Connector
Antenna Placement Guide
Powering
Power Requirements
Power requirements
Voltage 9-24v
Current 1A (~12W)
Sensor Connectivity
Analog Inputs pins
Analog Inputs
Analog Channel Speccifications
Channels 9 analog input channels, with 8 external and 1 internal for monitoring battery or supply voltage
Voltage Range 0-5V
Voltage Protection Up to 400V (intermittent)
ADC Precision 12-bit
Maximum Sample Rate 1000Hz
Mapping Can be configured as Raw, using a linear formula, or an interpolated map
Note: You can use an analog port to monitor the states of 12V switches, lights, or other 5V-12V On/Off devices. It is recommended to use an inline 10K 1/4 watt resistor to ensure proper functioning and protection of the system. The input should be mapped such that a voltage range of 0-3.0V corresponds to a state of 0, and a voltage range of 3.01V and above corresponds to a state of 1. Even when 12V is applied, the system will display a maximum of approximately 5V, ensuring safe monitoring and accurate state detection of the connected devices.
