RaceCapturePro Lua Scripting
Example Scripts and How-Tos
Lua Script Basics
Writing your script
onTick() function
Viewing the output log
Controlling the onTick() rate
count = 0
  count = count + 1
  println("Tick: " ..count)
Given:
  temperature = getAnalog(0)
  if temperature > 212 then
    setGpio(0, 1)
  else
    setGpio(0, 0)
Combining multiple functions
Example:
function checkTemps()
function checkAutoLogging()
  checkTemps()
  checkAutoLogging()
Debugging your script
Example:
    println("over temp!")
    setGpio(0, 1)
  else
    println("under temp")
    setGpio(0, 0)
Out of memory issues
function addSomeNumbers()
  local var1 = 3
  local  var2 = 5
  return var1 + var2
Simplify your script
 collectgarbage()
-- other code --
Try a Lua minimizer
Lua Reference
More examples
API Reference
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
  • returns:
    • none
getButton()
  • params
    • none
  • returns
PWM / Analog Output functions
  • params
  • returns
    • none
setPwmClockFreq( frequency )
  • params
  • returns
    • none
  • params
    • returns
  • none
Timer / RPM Sensor Functions
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFreq(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
Analog Sensor Functions
getAnalog(channel)
  • params
getImu(channel)
  • params
  • returns
getImuRaw(channel)
  • params
  • returns
    • The raw accelerometer value
GPS Sensor Functions
getGpsPos()
  • params
    • none
  • returns
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsSats()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getGpsDist()
  • params
    • (none)
  • returns
    • The distance, in Miles
getGpsAltitude()
  • Added: v2.9.0
  • Parameters: None
  • Returns: <altitude>
getGpsSec()
  • params
    • (none)
  • returns
Lap Statistics
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getPredTime()
as of 2.12.0 firmware
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
resetLapStats()
since 2.16.0
  • params
    • (none)
  • returns
    • (none)
Time Functions
getTickCount()
  • params
None
  • returns
CAN Bus functions
initCAN(channel, baud )
  • params
  • returns
  • params
  • returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
  • params
  • returns
Example:
  • params
  • returns
OBDII functions
readOBD2( PID )
  • params
  • returns
setOBD2Delay( delayMs )
  • params
    • The additional delay between PID queries, in ms
  • returns
    • none
Logger Control Functions
onTick()
  • params:
    • (none)
  • returns:
    • (none)
Example:
setTickRate(rate)
  • params
  • returns
    • (none)
SD storage
Functions to read / write values to SD storage. Only available on systems with SD card storage, or built-in flash storage.
loadVar()
Fetches a numerical value from SD with the specified name
  • params
    • name: name of the variable
  • returns
    • success: true if the value was fetched, false if not
    • value: value of the saved var. 0 if success is false
Example:
success, value = loadVar("my_var")
println("loadVar success: " ..tostring(success))
println("loadVar value: " ..value)
saveVar()
Stores a numerical value to SD with the specified name
  • params:
    • name: the name of the variable, maximum 64 characters.
    • value: the numerical value to save
  • returns
    • success: true if the value was successfully stored
Example:
success = saveVar("my_var", 1234)
println("saveVar success: " ..tostring(success))
SD Logging control
isLogging()
  • params
    • (none)
  • returns
startLogging()
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
LED control
setLed( led, state )
  • params
    • led (1-3)
  • returns
    • (none)
Telemetry Control
setBgStream( on/off )
  • params
  • returns
    • (none)
getBgStream()
  • params
    • (none)
  • returns
Serial Port Communications
Port mappings
  • 0 = USB port
  • 1 = GPS port
  • 3 = Bluetooth port
  • 4 = Auxiliary / WiFi port
    (RaceCapture/Pro MK2)
  • 5 = WiFi port
  • params
  • returns
readCSer( port, [timeout])
  • params
  • returns
readSer( port, [timeout])
  • params
    • port: Serial port 0 - 4
writeCSer( port, data )
  • params:
  • returns:
(no return values)
writeSer( port, data )
  • params
  • returns:
(no return values)
flashLoggerCfg()
  • params
    • (none)
  • returns
    • (none)
setPwmClockFreq( freq )
  • params
  • returns
    • (none)
getPwmClockFreq()
  • params
    • (none)
  • returns
calibrateImuZero()
  • params
    • (none)
  • returns
    • (none)
Virtual Channels
  • params
  • returns
  • Parameters
  • Returns
  • Examples:
val = getChannel(1)
--get the channel by name
rpm = getChannel("RPM")
if rpm ~= nil then
  • params
Example:
id = addChannel("EGT", 1)
   temp = temp * 1000
Time Info
getUptime()
  • Returns
getDateTime()
    • Year
    • Month
    • Day
    • Hour
    • Minute
    • Second
    • Millisecond
Dashboard Control
txButton()
Simulates button press events for dashboard navigation and control. RaceCapture dashboard must be connected for function to have effect.
  • params
    • button_id: ID of button to transmit. 0 = left button;1 = right button;2 = ack/yes;3 = no
  • returns
    • (nothing)
ShiftX2/3 control
sxSetConfig()
sxSetConfig()
  • params
  • returns
sxCfgLinearGraph()
  • params
  • returns
sxSetLinearThresh()
  • params
    • Red: Red LED value (0-255)
    • Flash: 0-10Hz (0 = sold on)
  • returns
sxUpdateLinearGraph()
  • params
  • returns
    • (none)
sxSetAlert()
  • params
  • returns
sxSetAlertThresh()
  • params
  • returns
sxUpdateAlert()
  • params
  • returns
sxSetDisplay()
  • params
    • Digit index (must be 0)
  • returns
sxSetLed()
  • params
  • returns
sxRxButton()
  • params
    • (none)
  • returns
    • button_id (ID of button. left button = 0, right button = 1, yes = 2, ok/no = 3)
Helper Functions
calcGear()
  • params
  • returns
  • params
    • Speed Channel name
    • RPM Channel name
  • returns
