Podium Driver Data Analysis
Getting Started
Installing the app
Get the latest version of the Podium app from the downloads page
Android / iOS
Setup and Configure Podium
After logging in, you’ll be welcomed by the home page interface.
The main sections include:
  • My Following: View the list of users whom you follow.
  • My Events: See the events you’ve created.
  • My Tracks: Browse tracks you’ve participated.
  • My Devices: Manage and view the devices you’ve registered.
In the Events tab, you’ll find:
  • Live Stream Events: Ongoing sessions from other users.
  • Recent Events: A history of completed events.
  • Upcoming Events: A schedule of events that are planned.
In the Tracks tab, you can:
  • Search for all tracks available in Podium.
  • Explore events that have taken place at each track.
When you select a device, either your own or another user’s device, the data appears in the Dashboard. Here you can:
  • Select up to three laps of your choice for comparison.
  • Stream and analyze the data in real time using customizable dashboards.
This is where you can dive into detailed performance insights and make the most out of your racing data. Start by picking a few of your fastest laps, usually 3 laps that are close in time, since we want to check your consistency. If you have data from a pro driver or coach, choose your two fastest laps and their fastest lap. This will clearly show you where you can improve.
Make sure you click on your fastest lap first, because the first lap you select becomes the reference lap in the Time Gap Graph. In the app, you have the option to either import a preset dashboard or fully customize your own. To do this, click on the settings icon in the top-right corner.
The first thing you want to do is find a few of your fastest laps and click on 3 of them. Ideally they will be laps close to each other as what we are analyzing is your consistency. Ideally, if you have a pro driver or coach who can set some reference data for you, click on your two fastest laps and their fastest lap. This will really show you where you can find time. Click on the fastest lap last, as the last lap you click on is used as the reference lap for the Time Gap Graph. Also make sure your graphs are by Distance and not Time. Now hide all the graphs we don't care about except Speed, Time Gap, AxcelX, AxcelY. You can keep RPM, Gear, Pitch and Yaw if you want. Customize the graphs so that the Min and Max values make sense for the data shown and give you the best resolution. Ie. If your car only rev's to 6000RPM, but max on the graph is 10000, maybe change the max to 6500.
To see how much time you are losing in a section, place the cursor where the time gap starts to dip or rise rapidly and note the current Time Gap for that lap. Then move the cursor to where the time gap line starts to level off and note the Time Gap for that lap at that point. The difference between those two Time Gap times, is how much time you are losing in the section. The sections with the largest time lost are the ones you should work on first.
The Why - Analyzing the data
Pro Tip: click image and read description to learn how to read the speed trace to see the differences between a pro driver and an advanced driver in the same car.
General Data Analysis tips
Unless comparing to a pro driver, you only need to look at one lap at a time for this, use your best lap. Compare to your second best lap to see if they are similar to rule out an anomaly.
Braking
Look at the Accel graph that shows acceleration and braking. This will either be AccelX or AccelY depending on how you mounted and setup your RCP. You can tell which is your acceleration/braking graph because braking is always a much larger curve than acceleration. Look for a graph with 0.2-0.3g's one side (acceleration) and over 1.0 g's on the other side (braking).
Your max braking G's should be similar to your max turning G's (within about 0.2g). If they are not close, it means you are not using your tires full potential for which ever graph is lower. Ie, if you are turning at 1.4g's, but your braking is only 1.0g, you can brake harder.
Throttle to Brakes transition
You can also see this in the speed trace. As you are accelerating it should be slowly rising and then immediately drop fast when you brake. If after accelerating, it levels out or drops slowly, before the real deceleration begins, it means they were either coasting or just lightly adding brakes before actually getting on the brakes hard.
You can also see this in the speed trace. The transition from acceleration to braking should look almost like a 90* angle. It should then be a straight line down. If it is rounded right before the real deceleration starts, or the line is not straight, you need to work on braking later and harder.
Heel-Toe
Look for a little blip in the braking trace. Or look for the speed trace to fall sharply, start to even out just the tiniest bit, then continue to fall sharply. This is where you are heel-toeing and let off a little brake pressure as you did so. You would need to work on your heel-toe without effecting the braking pressure. You can use the RPM trace to see exactly where you heel-toed under braking.
Now draw a straight line through all of your major braking zones (both on the speed trace and on the accel/braking graph). Assuming the track conditions are the same (not going up or down a hill) at the brake zones, all these lines for each graph should be almost perfectly parallel to each other. This would mean you are using the brakes consistently at every braking zone. If any are less steep than others, you can get on the brakes harder in those less steep sections.
Lateral G's
