TireX
High Performance
Rugged and Compact
Flexible Setup
Quick Setup Guide
  • RaceCapture system
  • Powered CAN hub kit
Hardware Setup
TireX 4-corner plug and play harness
We recommend using the TireX 4-corner plug and play harness for the easiest installation.
By System
For newer plug and play RaceCapture and PodiumConnect systems
Use the Dual CAN splitter
For a minimal installation, use the Dual CAN splitter
https://www.autosportlabs.com/product/can1-can2-dual-can-splitter/
This splitter connects to the dual CAN port of your system, and TireX connects to the CAN2 ("B" connection) branch on the splitter.
For older generation RaceCapture systems with RJ45 connector
Plug and Play option
Get the 8 port hub and dual CAN link cable -> RJ45
https://www.autosportlabs.com/product/powered-8-port-dual-can-bus-hub-kit/
https://www.autosportlabs.com/product/racecapture-rj45-to-dual-can-bus-link-cable/
The cable plugs into the RJ45 port of your RaceCapture/Pro, and then plugs into the hub. Then, the TireX harness plugs into the hub.
Minimal installation (requires some custom wiring)
Get the Device CAN pigtail
https://www.autosportlabs.com/product/can-power-pigtail-for-device/
For other data systems
TireX Connection
Connect Each TireX Sensor to the Wiring Harness
To maintain proper CAN bus signal integrity, connect the sensors in a daisy-chain configuration. Install the inline CAN terminator at the final sensor in the chain.
⚠️ Do not create star or branch connections. The CAN network must remain a single continuous chain.
Routing
Begin at the male connector end of the plug-and-play harness (data system connection) and route the harness in sequence around the vehicle.
Recommended cable segments:
  • Data system → Sensor 1 (first corner, front or rear): 3 m cable
  • Sensor 1 → Sensor 2 (opposite side of same axle): 3 m cable
  • Sensor 2 → Sensor 3 (same side, opposite axle): 4 m cable
  • Sensor 3 → Sensor 4 (final corner): 3 m cable — install inline terminator here
Example Layout (Data System Mounted Near Center of Vehicle)
  • Route a 3 m segment to the left-front corner and connect the sensor using the Y-splitter.
  • Route a 3 m segment across to the right-front corner and connect the sensor.
  • Route a 4 m segment to the right-rear corner and connect the sensor.
  • Route a 3 m segment to the left-rear corner and connect the final sensor.
  • Install the inline CAN terminator at this last sensor.
Software Setup
Enable the TireX CAN mapping
  • Go to Setup/CAN mapping
Ensure RaceCapture / TireX is powered by 12v
Using the overview gauge
Using the raw channels view
Feature Description
Sensor type Thermal array
Accuracy 1C
Processing Engine 32 bit
Electrical
Interface CAN 2.0
Power 200mW
Physical / Environmental
Construction CNC aluminum
Dimensions 64 x 46 x 12.5mm
Weight 10 grams
IP rating IP65
Dimensions / Mounting
Mounting Orientation
Mounting Distance
  • 205 width = 71mm
  • 225 width = 79mm
  • 235 width = 82mm
  • 245 width = 85mm
  • 255 width = 89mm
  • 275 width = 96mm
  • 315 width = 110mm
Electrical / CAN connection
Pin Connecton Wire Color
Pin 1 CAN Low Brown
Pin 3 CAN High Blue
Pin 4 Ground Black
CAN termination
Customizing Termination
Zone Configuration
Zones Coverage
CAN bus protocol
CAN protocol files
Formula
  • Example:
    • Formula: A / 100
    • Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value Symbol Reference
8 Bit values A
Default Main Base ID
Adjusting Main Base ID
Closed Closed 0xA100 (41216)
Closed Open 0xB100 (45312)
Open Closed 0xC100 (49408)
Open Open 0xD100 (53504)
Sensor Position Offset
0 Left-Front 0x0 (0)
1 Right-Front 0x100 (256)
2 Left-Rear 0x200 (512)
3 Right-Rear 0x300 (768)
Left-Front 0xA100
Right-Front 0xA200
Left-Rear 0xA300
Right-Rear 0xA400
CAN ID: Sensor Base ID + 0
3 Reserved
4 Reserved
CAN ID: Sensor Base ID + 2
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Preferences
CAN ID: Sensor Base ID + 3
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Calibration Preferences
CAN ID: Sensor Base ID + 4
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
Full Frame Mode
Hardware configuration
Disassembly and replacing harness
Disassembly steps:
Re-assembly steps:
