Ford EDIS technical information
Revision as of 07:25, 20 October 2008 by Brentp (talk | contribs) (→Crank pulley modifications: added alternate face-drilled version)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
If the crank pulley has extra material to machine the necessary 36-1 pattern, identically effective results can be obtained compared to the 'traditional' technique of mating trigger wheels with crank pulleys.
The pattern can be as elaborate as replicating the trigger wheel teeth pattern into the wheel to simply milling/drilling a series of holes representing the pattern. Regardless of technique used, it's imperative the pattern is accurately machined into the pulley. In the case of drilled holes, both the size and position must be machined carefully to ensure consistent ignition timing.
The following image is of an aftermarket VW pulley, modified with the 36-1 pattern using round holes realize the trigger wheel pattern.
courtesy of Alexander_Monday
Alternate coil wiring
The following oscilloscope image shows the current limiting 'feature' of the EDIS module. The EDIS module will automatically adjust the dwell time to charge the coil primary up to a pre-determined current limit.
--insert plot here--
The plot illustrates the effects of active current limiting. The coil driver wired with two primares shows 1/2 the dwell time of the other coil primary, wired normally.
