RaceCapture-Pro MK2
Autosport Labs RaceCapture is a powerful Data Acquisition and Control system for motorsport applications, presented at a break-through price.
If you are interested in participating in our beta test program, email us with your request, including a short note explaining how you might benefit from the system, and a bit on your relevant background and experience. This information will help us qualify you as a beta-tester. Previous 'good-citizen' beta-testers will receive preferred placement.
Impact
RaceCapture transcends most traditional "Data Logging" systems by virtue of its powerful processor and emphasis on outputs as well as inputs. The ability to perform Data Acquisition while controlling other devices and systems, coupled with flexible end-user customization, will powerfully differentiate RaceCapture from other data logging systems.
Significance
While the official application of RaceCapture is focused towards Race Car Data Acquisition, its powerful processor combined with a wealth of inputs and outputs also makes RaceCapture a general purpose automotive computer, one capable of handling many different tasks - limited only by your imagination. If the question is "Can RaceCapture do ...?" the answer will likely be 'Yes' and often with little to no external hardware support necessary.
At a Glance
Capabilities
Input and Output Channels
RaceCapture offers 20 input and output channels, enough to handle complex logging and control tasks.
- 7 dedicated analog input channels
- 3 dedicated frequency input channels
- Measure RPM, wheel speed, or any kind of periodic pulse. One channel is optically isolated for direct connection to ignition coil.
- 4 configurable analog,digital or frequency output channels
- 3 configurable digital channels, settable for input or output
- Receive input from switches; or configure as output and use to activate accessories or drive indicator lamps
- Input for precision 3 channel accelerometer module (+/- 2G per axis, 3G optional)
- Measure and log 3D G-Force in real-time with one of the industry's most accurate and precise accelerometers.
- GPS module input
- Auxiliary serial expansion port
- Interface to future interactive dash/display
Logging
- Store up to 2GB of logging data
Power
- Powerful 48MHz 32 bit ARM processor
- Power to perform high resolution logging and running complex, user-defined logic
Mechanical
- Compact, rugged design with good looks
- Unit measures approximately 4 x 3 inches (100 x 82 mm)
- On-board Status LEDs
The Intangibles
Flexibility
- Customize logging channels and frequency
- Control outputs based on the logic YOU define
- Powerful PC software to customize, view and analyze data
Infinite Possibilities
- Far more than a data-logging system: flexible Inputs and Outputs coupled with a powerful processor offers endless customization
- Open development process, frequent software updates and end-user customizable!
