RaceCapture-Pro MK2
Revision as of 15:21, 17 April 2009 by Brentp (talk | contribs) (→Input and Output Channels: added 4th axis information)
Autosport Labs RaceCapture is a powerful, multi-channel Data Acquisition and Control system for motorsport applications, presented at a break-through price.
Impact
RaceCapture transcends most traditional "Data Logging" systems by virtue of its powerful processor and emphasis on outputs as well as inputs. The ability to perform Data Acquisition while controlling other devices and systems, coupled with flexible end-user customization, will powerfully differentiate RaceCapture from other data logging systems.
Significance
While the official application of RaceCapture is focused towards Race Car Data Acquisition, its powerful processor combined with a wealth of inputs and outputs also makes RaceCapture a general purpose automotive computer, one capable of handling many different tasks - limited only by your imagination. If the question is "Can RaceCapture do ...?" the answer will likely be 'Yes' and often with little to no external hardware support necessary.
Beta testing in 2009!
If you are interested in participating in our beta test program, email us with your request, including a note about your relevant background and experience, and a section explaining how you might benefit from the system- specifically, the application in which you will be using RaceCapture (i.e. Street Car, Road Race, Rally, Drag, Autocross, etc.), and any particular objective you would like to meet with the system. This information will help us qualify you as a beta-tester. Previous 'good-citizen' beta-testers will receive preferred placement.
At a Glance
Capabilities
RaceCapture offers 20 input and output channels, enough to handle complex logging and control tasks.
  • Input for precision 3 channel accelerometer module plus Z-axis Gyro (+/- 2G per axis, 3G optional)
    • Z-axis Gyroscope measures Yaw/Drift in real-time.
  • GPS module input
Logging
Power
Mechanical
  • On-board Status LEDs
The Intangibles
Flexibility
Infinite Possibilities
Images
Board Connections
