Ford EDIS technical information
Revision as of 17:33, 25 July 2009 by Brentp (talk | contribs) (→Adapting OEM trigger wheel: added link to trigger wheel installations)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Trigger Wheel Installations
Crank pulley modifications
courtesy of Alexander_Monday
courtesy of pope101
Alternate coil wiring
