Ford EDIS technical information
Revision as of 23:52, 21 August 2009 by Brentp (talk | contribs) (Undo revision 1301 by Special:Contributions/Brentp (User talk:Brentp))
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Alternate coil wiring
