RaceCapture-Pro MK2
Revision as of 05:58, 27 April 2012 by Brentp (talk | contribs) (reformatting)
Autosport Labs RaceCapture/Pro is a powerful, multi-channel Data Acquisition and Control system for motorsport applications
Impact
RaceCapture/Pro transcends most traditional "Data Logging" systems by virtue of its powerful processor and emphasis on outputs as well as inputs. The ability to perform Data Acquisition while controlling other devices and systems, coupled with flexible end-user customization offers a unprecedented level of capability.
Significance
While the primary application of RaceCapture/Pro is focused towards Race Car Data Acquisition, its powerful processor combined with a wealth of inputs and outputs also makes RaceCapture a general purpose automotive computer, one capable of handling many different tasks - limited only by your imagination. If the question is "Can RaceCapture do ...?" the answer will likely be 'Yes' and often with little to no external hardware support necessary.
Capabilities
Input and Output Channels
    • Receive input from switches; or configure as output and use to activate accessories or drive indicator lamps with fully protected mosfet outputs
  • 4 Axis Accelerometer: 3 channel accelerometer module plus Z-axis Gyro (+/- 2G per axis, 3G optional)
    • Z-axis Gyroscope measures Yaw/Drift in real-time.
  • 10Hz GPS module input
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
  • Auxiliary Serial Port
Logging
Power
Mechanical
  • Compact, rugged design
  • On-board Status LEDs
The Intangibles
Flexibility
  • Desktop software to customize RaceCapture/Pro, view runtime data and analyze data
Infinite Possibilities
  • Fully Open Source System - Open Standards, Open File format. Frequent software updates and end-user customizable!
Board Connections
Images
