RaceCapture-Pro MK2
Impact
RaceCapture/Pro transcends most traditional "Data Logging" systems by virtue of its powerful processor and emphasis on outputs as well as inputs. The ability to perform data acquisition while controlling other devices and systems, coupled with flexible end-user customization offers a unprecedented level of capability.
Significance
Capabilities
Input and Output Channels
- 7 dedicated 0-5v analog input channels
- 3 dedicated 0-5v frequency input channels
- Measure RPM, wheel speed, or any kind of periodic pulse.
- 4 configurable analog,digital or frequency output channels
- 3 configurable digital channels, settable for input or output
- Receive input from switches or digital signals; or configure as output and use to activate accessories or drive indicator lamps with fully protected 1A mosfet outputs
- 4 Axis Accelerometer: 3 channel accelerometer module plus Z-axis gyro (+/- 2G per axis, 3G optional)
- Measure and log 3D G-force in real-time with one of the industry's most accurate and precise accelerometers.
- Z-axis gyroscope measures yaw/drift in real-time.
- 10Hz GPS module input
- Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
- Auxiliary Serial Port
- Interface to real time telemetry, bluetooth adapter, dashboard display or other interface
- Digital expansion port
- A high speed port provides the ability to add more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
- Store up to 32GB of logging data
Power
- Powerful 48MHz 32 bit ARM processor
- Power to perform high resolution logging and running complex, user-defined logic
Input/Output Protection
- 45v protection on all input pins
- Analog outputs protected by auto-resettable fuse
- digital outputs are rated at 1A with self-protected mosfets
- Over-current protection on 5V reference
- 2A internal switching power supply
Mechanical
- Compact, rugged design
- Unit measures approximately 4 x 3 inches (100 x 82 mm)
- On-board Status LEDs
The Intangibles
Flexibility
- Customize logging channels and frequency
- Control outputs based on the logic YOU define
- Desktop software to customize RaceCapture/Pro, view runtime data and analyze data
Infinite Possibilities
- Far more than a data-logging system: flexible Inputs and Outputs coupled with a powerful processor offers endless customization
- Fully Open Source System - Open Standards, Open File format. Frequent software updates and end-user customizable!
