RaceCapturePro Lua Scripting
This page is under construction. Check back soon!
Scripting functions for RaceCapture/Pro
getGpio
Retrieves the state of the GPIO ports
state getGpio(port)
  • params: port - integer 0 - 2
  • returns: 1 = port is high, 0 = port is low
When the port is configured for input mode, a voltage high input (> 2 volts) will read as 1; a voltage low will read as 0. A disconnected port will read as high due to the internal pullup resistor.
When the port is configured as output, the port reads 1 when the port is activated (output transistor is connected to ground) and 0 when the port is deactivated (pullup resistor is active)
setGpio
Sets the state of the GPIO port when the port is configured for output mode.
setGpio(port, state)
  • params: port - integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns: none
When the state specified is 1, the output is active (transistor is conneced to ground). When state is 0, transistor is disconnected, and pullup resistor is active.
getButton
state getButton()
  • params: none
  • returns: 1 = pushbutton is depressed; 0 = pushbutton is not depressed
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
  • params: none
  • returns: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable
Indicates if the SD card is writable (lock switch on SD card is active)
writable isSDCardWritable()
  • params: none
  • returns: 1 = SD card is writable; 0 = SD card is not writable
setPWMDutyCycle
setPWMDutyCycleRaw
setPwmPeriod
setPwmPeriodRaw
setAnalogOut
getTimerRpm
getTimerPeriodMs
getTimerPeriodUsec
getTimerFrequency
getTimerRaw
resetTimerCount
getTimerCount
getAnalog
getAnalogRaw
readSerial
writeSerial
getGpsLatitude
getGpsLongitude
getGpsSpeed
getGpsQuality
getGpsTime
getLapCount
getLapTime
getGpsSec
getAtStartFinish
getTimeDiff
getTimeSince
getAccel
getAccelRaw
startLogging
stopLogging
setLed
flashLoggerConfig
setAnalogSampleRate
getAnalogSampleRate
setAnalogScaling
getAnalogScaling
setPwmClockFrequency
getPwmClockFrequency
setPwmSampleRate
getPwmSampleRate
setPwmOutputConfig
getPwmOutputConfig
setPwmLoggingConfig
getPwmLoggingConfig
setPwmStartupDutyCycle
getPwmStartupDutyCycle
setPwmStartupPeriod
getPwmStartupPeriod
setPwmVoltageScaling
getPwmVoltageScaling
setGpsInstalled
getGpsInstalled
setGpsStartFinish
getGpsStartFinish
setGpsPositionSampleRate
getGpsPositionSampleRate
setGpsSpeedSampleRate
getGpsSpeedSampleRate
setGpsTimeSampleRate
getGpsTimeSampleRate
setLapCountSampleRate
getLapCountSampleRate
setLapTimeSampleRate
getLapTimeSampleRate
setGpioSampleRate
getGpioSampleRate
setGpioConfig
getGpioConfig
setTimerSampleRate
getTimerSampleRate
setTimerConfig
getTimerConfig
setTimerPulsePerRevolution
getTimerPulsePerRevolution
setTimerDivider
getTimerDivider
calculateTimerScaling
getTimerScaling
setAccelInstalled
getAccelInstalled
setAccelSampleRate
getAccelSampleRate
setAccelConfig
getAccelConfig
setAccelChannel
getAccelChannel
setAccelZeroValue
getAccelZeroValue
calibrateAccelZero
