RaceCapturePro Lua Scripting
Revision as of 17:47, 5 May 2013 by Brentp (talk | contribs) (added more documentation)
This page is under construction. Check back soon!
Scripting functions for RaceCapture/Pro
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
    • channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns:
    • none
getButton()
  • params
    • none
  • returns
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
  • params
    • none
  • returns
    • present: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable()
Indicates if the SD card is writable (lock switch on SD card is active)
  • params
    • none
  • returns
    • writable: 1 = SD card is writable; 0 = SD card is not writable
  • params
  • returns
    • none
setPwmPeriod( channel, period )
  • params
    • period: The period value
    • returns
  • none
  • params
    • returns
  • none
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFrequency(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
getAnalog(channel)
  • params
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
  • params
    • returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
readSerial(port)
  • params
    • port: Serial port 0 - 1
    • returns: a line of serial data
writeSerial(port, data)
  • params
getGpsPosition()
Reads the current position as measured by the attached GPS module coming in firmware 1.2
  • params
    • none
  • returns
getGpsLatitude()
Provides the current latitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
  • params
    • (none)
  • returns
    • The current latitude in decimal degrees
getGpsLongitude
Provides the current longitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
  • params
    • (none)
  • returns
    • The current longitude in decimal degrees
getGpsSpeed
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality
  • params
    • (none)
  • returns
getGpsTime
  • params
    • (none)
  • returns
    • The current GPS time value
getLapCount
  • params
    • (none)
  • returns
getLapTime
  • params
  • (none)
  • returns
getGpsSec
getAtStartFinish
getTimeDiff
getTimeSince
getAccel
getAccelRaw
startLogging
stopLogging
setLed
flashLoggerConfig
setAnalogSampleRate
getAnalogSampleRate
setAnalogScaling
getAnalogScaling
setPwmClockFrequency
getPwmClockFrequency
setPwmSampleRate
getPwmSampleRate
setPwmOutputConfig
getPwmOutputConfig
setPwmLoggingConfig
getPwmLoggingConfig
setPwmStartupDutyCycle
getPwmStartupDutyCycle
setPwmStartupPeriod
getPwmStartupPeriod
setPwmVoltageScaling
getPwmVoltageScaling
setGpsInstalled
getGpsInstalled
setGpsStartFinish
getGpsStartFinish
setGpsPositionSampleRate
getGpsPositionSampleRate
setGpsSpeedSampleRate
getGpsSpeedSampleRate
setGpsTimeSampleRate
getGpsTimeSampleRate
setLapCountSampleRate
getLapCountSampleRate
setLapTimeSampleRate
getLapTimeSampleRate
setGpioSampleRate
getGpioSampleRate
setGpioConfig
getGpioConfig
setTimerSampleRate
getTimerSampleRate
setTimerConfig
getTimerConfig
setTimerPulsePerRevolution
getTimerPulsePerRevolution
setTimerDivider
getTimerDivider
calculateTimerScaling
getTimerScaling
setAccelInstalled
getAccelInstalled
setAccelSampleRate
getAccelSampleRate
setAccelConfig
getAccelConfig
setAccelChannel
getAccelChannel
setAccelZeroValue
getAccelZeroValue
calibrateAccelZero
