RaceCapturePro Lua Scripting
This page is under construction. Check back soon!
Scripting functions for RaceCapture/Pro
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
- returns:
- none
getButton()
- params
- none
- returns
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
- params
- none
- returns
- present: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable()
Indicates if the SD card is writable (lock switch on SD card is active)
- params
- none
- returns
- writable: 1 = SD card is writable; 0 = SD card is not writable
- params
- returns
- none
setPwmPeriod( channel, period )
- params
- period: The period value
- returns
- none
- params
- returns
- none
getTimerRpm(channel)
- params
- channel: Timer channel 0 - 3
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFrequency(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
getAnalog(channel)
- params
- channel: Analog input channel 0 - 7
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
- params
- returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
readSerial(port)
- params
- port: Serial port 0 - 1
- returns: a line of serial data
writeSerial(port, data)
- params
getGpsPosition()
Reads the current position as measured by the attached GPS module coming in firmware 1.2
- params
- none
- returns
getGpsLatitude()
Provides the current latitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
- params
- (none)
- returns
- The current latitude in decimal degrees
getGpsLongitude()
Provides the current longitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
- params
- (none)
- returns
- The current longitude in decimal degrees
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff(time1, time2)
- params
- time1
- time2
- returns
getTimeSince(time)
- params
- time
- returns
getAccel(channel)
- params
- channel
- returns
- The accelerometer value scaled to actual G force, averaged across 10 samples
getAccelRaw(channel)
Reads the raw ADC value of the specified accelerometer channel
- params
- channel
- returns
- The raw accelerometer value, averaged across 10 samples
startLogging()
Begins a logging session
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed(led, state)
- params
- led (1-3)
- returns
- (none)
flashLoggerConfig()
- params
- (none)
- returns
- (none)
setAnalogSampleRate(channel, rate)
Sets the sample rate for the specified channel
- params
- channel
- sampleRate
- returns
- (none)
getAnalogSampleRate()
Gets the sample rate for the specified channel
- params
- (none)
- returns
- (none)
setAnalogScaling(channel, scaling)
Sets the linear analog scaling value for the specified channel
- params
- channel: the analog channel
- scaling: the scaling value
- returns
- (none)
getAnalogScaling(channel)
Gets the linear analog scaling value for the specified channel
- params
- returns
- the scaling value
setPwmClockFrequency(freq)
- params
- returns
- (none)
getPwmClockFrequency()
- params
- (none)
- returns
setPwmSampleRate(channel, rate)
Sets the sample rate for the specified PWM channel
- params
- channel: the PWM channel
- rate: the sample rate to set
- returns
- (none)
getPwmSampleRate(channel)
Gets the PWM sample rate for the specified PWM channel
- params
- returns
- rate: the currently configured sample rate
setPwmOutputConfig(channel, config)
Sets the output configuration for the specified PWM channel. Note, the hardware dip switch settings must match the configuration set here.
- params
- config: the PWM configuration. 0 = analog output; 1 = PWM output
getPwmOutputConfig(channel)
Gets the output configuration for the specified PWM channel. Note, the hardware dip switch settings must match the value returned here
- params
- channels: the PWM channel
- returns
setPwmLoggingConfig(channel, config)
Sets the logging configuration for the specified PWM channel
- params
- channel : the PWM channel 0 - 3
- config: the logging configuration. 0 = PWM period; 1 = PWM duty cycle; 2 = PWM volts
- returns
- (none)
getPwmLoggingConfig(channel)
Gets the logging configuration for the specified PWM channel
- params
- return
setPwmStartupDutyCycle(channel, dutyCycle)
Sets the PWM duty cycle for the specified channel applied at system start-up.
- params
- dutyCycle: the duty cycle, 0 - 100
getPwmStartupDutyCycle(channel)
Gets the PWM duty cycle for the specified channel applied at system start-up.
- params
- returns
setPwmStartupPeriod(channel, period)
Sets the PWM period for the specified channel at system start-up.
- params
- channel: the PWM channel 0 - 3
- period: the PWM period todo: define period units
- returns
- (none)
getPwmStartupPeriod(channel)
Gets the PWM period for the specified channel at system start-up.
- params
- returns
setPwmVoltageScaling(channel, scaling)
Sets the voltage scaling for the specified channel at system start-up.
- params
- returns
- (none)
getPwmVoltageScaling(channel)
Gets the voltage scaling for the specified channel at system start-up.
- params
- returns
- (none)
