Megajolt
The Megajolt2 Family
The Megajolt family represents the line of programmable, crank fired ignition control systems.
Megajolt/2
Megajolt/2 is a high performance programmable crank-fired ignition system optimized for 4 cylinder applications
Capabilities
- 4,6 or 8 cylinders in wasted spark mode
- 15K RPM capable
- 0.1 degree timing resolution
- 32 bit Infineon XMC4000 - 120MHz
- Single VR Sensor input
- 2 on-board coil drivers
- Soft and hard rev limit
- Designed to work with commodity OEM sensors and coil packs
- Initial support for 36-1 trigger wheel; other trigger wheel configurations to follow
- up to 16x16 ignition map with linear interpolation
- Dual, on the fly switchable ignition map support
- 2 User defined digital outputs
- 3 analog input channels
- Throttle Position, Temperature and Aux
- Ignition advance correction for Temperature and Aux
- On-Board MAP sensor
- USB or Bluetooth programming interface
Megajolt/C
Summary
Megajolt/C is a Programmable Crank Fired ignition targeted for intelligent coil-on-plug modules or external igniter applications.
Capabilities
- Supported configurations
- Up to 8 cylinders in true coil-on-plug mode
- Up to 12 cylinders in wasted spark mode
- 15K+ RPM capable
- Dual VR Sensor input
- Crank Sensor + Cam Angle Sensor input
- 8 logic-level coil driver outputs
- Designed to drive coil-on-plug or coil-near-plug modules such as the GM LS-1, LS-2, BMW or similar coil modules with built-in coil drivers
- TPS, Temperature and Aux
- Ignition correction for Temperature and Aux
Megajolt/Micro
Summary
Ultra compact EDIS ignition control
Capabilities
- 4,6,8 cylinders
- Soft Rev Limit capable
- 1 degree timing resolution
- 10x10 ignition map with linear interpolation
- TPS/MAP, temperature and Aux input
- 2 User-defined digital outputs
- Provision for on-board MAP sensor
- Bluetooth interface option
