Ford EDIS technical information
Revision as of 03:00, 12 April 2007 by Brentp (talk | contribs) (reverted table formating, clarified first sentence)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
