RaceCapturePro Lua Scripting
Revision as of 00:28, 8 December 2014 by Brentp (talk | contribs) (→CAN Bus functions: updated / clarified CAN API documentation)
Example Scripts and How-Tos
Lua Scripting Examples
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
    • channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns:
    • none
getButton()
  • params
    • none
  • returns
PWM / Analog Output functions
  • params
  • returns
    • none
setPwmPeriod( channel, period )
  • params
    • period: The period value
    • returns
  • none
  • params
    • returns
  • none
Timer / RPM Sensor Functions
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFreq(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
Analog Sensor Functions
getAnalog(channel)
  • params
getAccel(channel)
  • params
    • channel (0 - 2 for accelerometer, 3 for yaw gyro sensor)
  • returns
getAccelRaw(channel)
  • params
  • returns
    • The raw accelerometer value
GPS Sensor Functions
getGpsPos()
  • params
    • none
  • returns
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getGpsDist()
  • params
    • (none)
  • returns
    • The distance, in Miles
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getGpsSec()
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
getTimeDiff(time1, time2)
  • params
    • time1
    • time2
  • returns
getTimeSince(time)
  • params
    • time
  • returns
CAN Bus functions
initCAN(channel, baud )
  • params
  • returns
  • params
  • returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
  • params
    • timeout (optional). read timeout in milliseconds. defaults to 100ms
  • returns
Example:
  • params
  • returns
readOBD2( PID )
  • params
  • returns
Logger Control Functions
onTick()
  • params:
    • (none)
  • returns:
    • (none)
Example:
setTickRate(rate)
  • params
  • returns
    • (none)
startLogging()
Begins a logging session
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
setLed( led, state )
  • params
    • led (1-3)
    • state : 1 = on, 0 = off
  • returns
    • (none)
readSerial( port )
  • params
    • port: Serial port 0 - 1
    • returns: a line of serial data
writeSerial( port, data )
  • params
flashLoggerCfg()
  • params
    • (none)
  • returns
    • (none)
setPwmClockFreq( freq )
  • params
  • returns
    • (none)
getPwmClockFreq()
  • params
    • (none)
  • returns
calibrateImuZero()
  • params
    • (none)
  • returns
    • (none)
Virtual Channels
available in firmware 2.0 Adds a virtual channel. This virtual channel remains in memory during runtime; it is not persisted in the configuration. Up to 10 virtual channels can be created.
  • params
    • name: The name of the channel. Must be a channel name known to the system, up to 10 characters long.
  • returns
  • params
Example:
id = addChannel("EGT", 1) --channel name EGT must exist in the list of known channels
   temp = temp * 1000
